FINALLY DONE! not tuned tho
Old May 30, 2008 | 01:49 PM
  #26
Boostedb20EH2's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">
Reading owns you. Unless you consider 100 octane as pump gas. Anything more is a waste, especially for a car that will spend time on the street with DOT-approved tires. He'd also have to get a larger turbo to go a lot higher, increasing spool time.</TD></TR></TABLE>
What the hell are you talking about?
Old May 30, 2008 | 01:52 PM
  #27
mangina's Avatar
talked to Robert at Golden Eagle
he said its not true, 30+ psi is ok
Old May 30, 2008 | 05:19 PM
  #28
FRernesto's Avatar
Default Re: (turbo boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo boost &raquo;</TD></TR><TR><TD CLASS="quote">
i never heard of this either?
can someone elaborate on this??</TD></TR></TABLE>
This is right on the paper that comes from golden GE..It states torque and PSI rating depending on the conditions. I have the sheet from GE, I believe it says 80lbs of TQ on head studs with no o-rings maxium 15lbs of boost.
Old May 30, 2008 | 06:05 PM
  #29
mangina's Avatar
yes, I read it on the site but I called GE and was told its not true.
I hope everything is good.
glad you let me know about that though
Old May 30, 2008 | 06:46 PM
  #30
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (mangina)
sick set up
Old May 30, 2008 | 10:18 PM
  #31
Dartanian's Avatar
Love the setup. Now THAT is a well put together machine. Maybe I missed it but what are you using for management?
In for dyno numbers...
Old May 30, 2008 | 10:41 PM
  #32
SleevedSensation's Avatar
nice setup hommie
Old May 31, 2008 | 03:13 AM
  #33
mangina's Avatar
I have a hondata s300 for engine management.
Old May 31, 2008 | 08:47 AM
  #34
FRernesto's Avatar
Yeah no problem, I was just curious when I saw the block and I didn't notice any rings I thought maybe you had your head o-ringed. Good luck man!!
Old May 31, 2008 | 12:11 PM
  #35
mangina's Avatar
hope that the 15psi deal is not true.
thanks for the comments
Old May 31, 2008 | 02:00 PM
  #36
Sr420Det's Avatar
Nice set up, do you ever take it to the drag strip in fayetteville? Id love to see that thing in action and maybe even get my *** kicked lol.
Old May 31, 2008 | 02:24 PM
  #37
mangina's Avatar
I had a evo8 I used to race up there.
havent raced the integra yet, im sure it will be faster
Old May 31, 2008 | 03:54 PM
  #38
dbang003's Avatar
car looks great! i just want to make 1 suggestion and that is to get rid of the Tee fitting on the back of the block for the oil feed. i've had terrible luck with them craking and pissing out all the oil. now i just run a braided line up to a Tee and that keeps it from bouncing around and cracking. just my $0.02 though. good luck with it.
-drew
Old May 31, 2008 | 05:40 PM
  #39
mangina's Avatar
was thinking about getting the one from stealthmode.
thanks for the advice
tepid1
Sep 21, 2009 02:41 PM
Globe1896
Aug 27, 2008 01:43 PM
lsvtechatch92
Nov 30, 2007 09:08 PM
B18C1CYA
May 29, 2005 02:28 PM
Blown90hatcH
Nov 28, 2004 09:34 PM
