Finally boosted
Old Jun 27, 2002 | 06:40 PM
johnmay19's Avatar
Default Finally boosted
After 12 hours of work I am finally boosted. Just a few things left to patch up and I will be done and ready to test drive. Here is my setup 94 civic coupe w/gsr Drag3, Hondata 2b, Dsm injectors, full 3'' Dp back exhaust and other little odds and ends. Thanks to honda-tech for all the tips and advice.
Old Jun 27, 2002 | 10:04 PM
Dutchie's Avatar
Default Re: Finally boosted (johnmay19)
Cool, hope the car works well for ya. How much boost will you be running? Let us know how it feels after the test drive. That is, if you can stop driving .
Old Jun 28, 2002 | 12:00 AM
eddie1681's Avatar
New User
Have Fun!!!
Old Jun 28, 2002 | 08:34 PM
johnmay19's Avatar
Default Re: Finally boosted (Dutchie)
I have the tial, so 6.5 for now. Haven't got to fully test, since I need to get a fuel pressure gague. Was hooking one up and the adapter snapped in the filter(sucked). Starts going lean into boost, despite repeated fpr adjustments. Does anyone have experience with the bbk fuel pumps, could possibly be my problem.
Old Jun 28, 2002 | 10:13 PM
rice4life's Avatar
you are probably running more like 5psi at the intake manifold since you loose pressure after the intercooler. my guage reads 5psi with the stock spring, but i have apexi avc-r to crank up the boost.
Old Jun 29, 2002 | 10:17 AM
Dutchie's Avatar
The BBK is the same as the Walbro, if it is an intank pump. Do you have a friend that you could switch with? Or, do you still have the stocker? The stock pump should be able to supply enough fuel for 5 psi, which is probably what you are running after drop. The only difference will be your base pressure might drop a bit. I would install the pressure guage, and see what your base pressure is. Then put in the stocker and adjust your base pressure up to where it was with the BBK. If it runs good then your pump is screwed. Another thing you could do is put the guage on, and take it to a dyno, and see if the pressure drops off under boost.
Old Jun 29, 2002 | 12:15 PM
99SilverEx's Avatar
Cool beans man, keep us posted sounds like your gonna have a quick ride.
Old Jun 29, 2002 | 02:59 PM
johnmay19's Avatar
Thanks for the info. Hopefulley it's not the pump, not that old. At the manifold I am reading 6lbs. I am looking to get the B&M fpg, anyone have one for sale?
CivicSi95
Feb 18, 2009 12:59 PM
ragethemachine86
Jul 22, 2006 01:37 AM
ragethemachine86
Jul 21, 2006 06:21 PM
playahwitgame
Jul 1, 2006 06:45 AM
madman604
Sep 25, 2002 11:08 AM
