finally on boost
Old Dec 21, 2004 | 12:18 PM
Denis aka CiViC4dr's Avatar
Default finally on boost
hey guys here's my homemade turbo setup
D16Z6 w/double headgasket
Garret T3 .48 w/GIK Wastegate
JB Intercooler
Homemade IC piping
Homemade Manifold
Homemade Downpipe 2.5"
SecretPower Blow off
ERL MF2 w/4x220ccm injectors
Toyota Mapsensor 2bar(29psi)
Homemade 2.5" exhaust all the way
5Zigen Muffler
Old Dec 21, 2004 | 12:24 PM
tgreaves's Avatar
Default Re: finally on boost (Denis aka CiViC4dr)
Why did you put a double gasket on a z6 motor? Also a 2 bar map sensor doesnt go up to 29psi, Its more like 22 psi..
Other than that everything looks great with your setup..
Old Dec 21, 2004 | 12:27 PM
CivicEJ1's Avatar
Old Dec 21, 2004 | 12:29 PM
the double headgasket lowerd the Compression and it's done a few times here,and it works,so I hope I can boost near 1 bar,and i thought that 1bar=14psi
Old Dec 21, 2004 | 12:34 PM
tgreaves's Avatar
Default Re: (Denis aka CiViC4dr)
No reason to lower the compression.. Youll just need more boost to make the same power but its your motor..
And 1bar does = 14.5 psi..
It supports 2 complete bars of pressure but part of that is for vacuum and the rest is for positive pressure..
Old Dec 21, 2004 | 12:41 PM
Default Re: (tgreaves)
yaa it's my first time on boost so we'l see how much power it's going to make,and how fast she would be....
Old Dec 21, 2004 | 12:50 PM
ladysman's Avatar
A 2 bar sensor is only good for 14.5 psi.
Old Dec 21, 2004 | 12:58 PM
Default Re: (ladysman)
yeah i know,but this one can handle 2bar off pressure
Old Dec 21, 2004 | 01:00 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Denis aka CiViC4dr &raquo;</TD></TR><TR><TD CLASS="quote">yeah i know,but this one can handle 2bar off pressure</TD></TR></TABLE>
Then it isn't a 2 bar sensor, it is a 3.
Old Dec 21, 2004 | 01:03 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
Then it isn't a 2 bar sensor, it is a 3.</TD></TR></TABLE>
ok,soo I learn something new now.thx
Old Dec 21, 2004 | 01:05 PM
el arbi's Avatar
Nice job on the kit
Old Dec 21, 2004 | 02:17 PM
mrbsponge's Avatar
look spretty good, what did you make all that intercooler piping from???
Old Dec 21, 2004 | 02:20 PM
b16sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">No reason to lower the compression.. Youll just need more boost to make the same power but its your motor..
It supports 2 complete bars of pressure but part of that is for vacuum and the rest is for positive pressure..</TD></TR></TABLE>
And gosh, with that full point drop in compression he might need to run an extra 1/2 of a pound of boost
Old Dec 21, 2004 | 02:29 PM
nonvtecD's Avatar
FYI, a 1 bar map sensor can't read boost, OBD1 Hondas have a 1.75 bar map that can read 11 psi or so...
Old Dec 21, 2004 | 03:04 PM
platinum00's Avatar
engine and car look great.
now clean that garage. it looks worse then mine.
platinum.
Old Dec 21, 2004 | 04:29 PM
tub_sephiroth's Avatar
That valve cover job is HOT!!!!!!!!1
Old Dec 21, 2004 | 04:46 PM
Blackack26's Avatar
Default Re: finally on boost (tub_sephiroth)
Looks good man
Old Dec 21, 2004 | 05:03 PM
TURBODC4TEG's Avatar
Default Re: finally on boost (Blackack26)
congrats
Old Dec 21, 2004 | 06:06 PM
Btothe3rdDegree's Avatar
Default Re: finally on boost (TURBODC4TEG)
it looks like some guy smiling with buck teeth LOL
looks good though
Old Dec 21, 2004 | 07:55 PM
Mykizism's Avatar
wow that garage is a mess :D
love that red and silver engine theme
Old Dec 21, 2004 | 08:20 PM
lone's Avatar
Default Re: (Mykizism)
that engine paint job gets a from me. its hot
Old Dec 21, 2004 | 08:22 PM
evosol's Avatar
looks good... hows it drive?
Old Dec 21, 2004 | 08:23 PM
Finland's Avatar
wow, pretty setup. The silver and red looks beatiful. I'm not sure I agree with the double head gasket idea, but hope it works for you.
Old Dec 21, 2004 | 09:03 PM
93turbo16's Avatar
i agree with the 3 bar map sensor thing. Very clean setup. I like.
Old Dec 22, 2004 | 01:59 AM
TurboEH2's Avatar
Default Re: (93turbo16)
homemade manifold? looks good man. where did u get that exhaust flange? bumper is different also, i kinda like it
