final checklist for the Drag install.....tia for helping..
Old Oct 21, 2001 | 01:22 AM
Flamenco-T's Avatar
Default final checklist for the Drag install.....tia for helping..
okay, I am planning on installing the drag kit on my GSR next weekend...
I am just going to run down the list of things that I need some clarification...
1. I receive a 45deg steel elbow with Drag stamp on it, I assume it is going for the intake arm on the compressor side, Correct ?
2. Gaskets gaskets and gaskets....
Do I need it and which ones do I need to get
-manifold to turbine
-manifold to head (replace with the new factory gasket ?)
-wastegate to manifold (art told me not to use the ones supplied by tial, which one should I get ?)
-turbine to downpipe
-Oil pan gasket (replace with new factory gasket ?)
-Any other gasket I didn't mention ?
3. Vaccum lines to wastegate fittings, FMU and all other vaccum fittings, will I need a small clamps or will a zip-ties be sufficient enough ?
4. I was planning to port or smooth out the inside surface of the manifold, BOV fittings in the charge pipe, downpipe and etc....what tip of dremmel did you guys uses ? I have used 2 grinding tips and doesn't seem to work really well...any other ideas ?
5. What's the easiest way to unbolt the Oil pan, specifically the two bolts that are underneath the flywheel cover ? How do I take off the flywheel cover ?
6. After I port the inside of manifold, dp, bov fittings, what's the best way to clean all the metal shavings from it ? use an air compressor (gas station) or will a thorough water rinse be sufficient enough ?
7. Any Drag supplies bolts I need to replace ? I have heard some that manifold or DP bolts need to be replaced with a stronger grade..which ones ?
I appreciate all the responses more or less...
Old Oct 21, 2001 | 04:17 AM
GruvyTune's Avatar
New User
Default Re: final checklist for the Drag install.....tia for helping.. (flamenco)
are gaskets necessary for the turbo to manifold and turbo to wastegate?
Fmax's does not include one and says to use permatex copper to form a good seal.
Old Oct 21, 2001 | 07:53 AM
Rory Breaker's Avatar
Default Re: final checklist for the Drag install.....tia for helping.. (GruvyTune)
Good luck brotha!
Old Oct 21, 2001 | 07:55 AM
b18bturbo's Avatar
If you need help i can do it under 5 hrs now..
Flamenco-T's Avatar
Default Re: final checklist for the Drag install.....tia for helping.. (newgsrdriver)
Good luck brotha!
thanks bro...
Old Oct 21, 2001 | 08:03 AM
Flamenco-T's Avatar
Default Re: final checklist for the Drag install.....tia for helping.. (b18bturbo)
Thanks Vireen...
I am more worried of the vaccum lines especially on running them and etc...
I can pretty much getaway with the major hardware parts, is the vaccum lines is what I am really worried about and all the unexpected little obstacles such as imperfect fit and etc.
Art and chris is going to help me out...btw where about do you live ?
thanks again
Old Oct 21, 2001 | 08:05 AM
b18bturbo's Avatar
I on Garland Side closer to 190
Old Oct 21, 2001 | 08:18 AM
Flamenco-T's Avatar
great !!, I am gonna do the install in Chris's place in carrollton by 190
if it's cool with him, it'll be great if you can come over and check my lines and etc...
Old Oct 21, 2001 | 08:24 AM
b18bturbo's Avatar
not a prb just give me directions i can make it next week no prb.
Old Oct 21, 2001 | 08:32 AM
Flamenco-T's Avatar
thanks...
Old Oct 21, 2001 | 01:39 PM
Etylorcen's Avatar
The kit should come w/ all the clamps and hoses you need, I would never use a zip tie to hold on a hose. The flywheel cover is real easy to get off. Its just a couple of nuts and 1 bolt if memory serves me correctly. Once you got all the nuts and screws out you gotta wiggle the cover off then you have access to all the bolts and nuts for the oil pan. Thing that confused me was that on the oil pan there are some nuts and the other bolts. You'd think they'd stay consistent, go figure. I haven't heard about replacing the bolts but you definately should replace the oil return line. Cost me about 65 bucks for everything.
Old Oct 21, 2001 | 05:40 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: final checklist for the Drag install.....tia for helping.. (Etylorcen)
Viren I'll be there also so maybe we could hang out and have a couple of beers..
Old Oct 21, 2001 | 06:03 PM
b18bturbo's Avatar
whats wrong with using zip ties to hold hoses. the hose from the BOV and the WASTEGATE usually can be tied with a zip tie as well as the fpr and fmu hoses.
Old Oct 21, 2001 | 06:09 PM
Flamenco-T's Avatar
Default Re: final checklist for the Drag install.....tia for helping.. (Arturbo)
if that's the case, then the is on me..
Old Oct 21, 2001 | 07:39 PM
Flamenco-T's Avatar
while we're on the subject....shouldn't I receive some plastic T fittings ?
I mean how can I connect the vacuum lines without it ?
also I only receive about three feet of silicone hose for the vacuum lines, is that going to be enough ?
and I alos receives two raidator like hoses, one is about 6" and 3/8" in diameter and the other ones is about 2.5" and about 1/2" in dia. I assume these are for oil return lines..
TIA
stan
Old Oct 22, 2001 | 12:13 AM
Anthony K's Avatar
New User
My kit didn't come with the bolts to bolt down the downpipe or the bolts that connect your test pipe to the cat back system. Make sure you have yours, they're supposed to come with the kit.
[Modified by Anthony K, 9:16 AM 10/22/2001]
Old Oct 22, 2001 | 06:35 AM
b18bturbo's Avatar
that is correct oil return lines and the silcone vacuum hose is plenty unless you tap of different places. You can just go local parts store and get vacuum line if need be.
Morhpeous
Jun 29, 2006 08:12 AM
Boofster
Oct 18, 2004 01:29 PM
trbob16a
Feb 5, 2004 05:45 AM
R-1303
May 25, 2003 07:48 AM
accordexchange
May 14, 2003 08:15 PM
