few questions before i boost.
Old Apr 17, 2004 | 09:10 PM
jbell's Avatar
Default few questions before i boost.
im planning this, all in a del sol:
b16 block and head
type r tranny (since getting it will be cheaper than getting a gsr and an lsd.)
del sol vtec axles, half shaft, and shift linkage
p28 hondata chipped ecu + boost.
drag turbo kit (will the eg civic piping work on the del sol?)
few questions first:
-since the sol will be obd1, where can i get an obd1 b16? since im just buying the block/head from hmotors, will that even matter, or does it solely depend on the ecu?
-what ecu should i run? i've been told a chipped p28... i figure that means a p28 running hondata + boost...
-will the eg civic piping work on the del sol?
Old Apr 18, 2004 | 08:20 AM
jbell's Avatar
Default Re: few questions before i boost. (jbell)
bump
Old Apr 18, 2004 | 07:31 PM
jbell's Avatar
also- will the sensors from the d15 or d16 del sol work on the b16 swap?
Old Apr 18, 2004 | 07:34 PM
boosted_dc2's Avatar
you should post this in the swap forum. but all that matters is that you run an obd1 ecu, and i think youll need an obd1 dizzy but im not sure on this.
Landon
97reddelsol
Jul 7, 2012 04:23 AM
coryfenton
13
Jul 16, 2009 04:18 PM
ek coupe
23
May 13, 2009 08:04 PM
Username001
May 18, 2008 12:55 PM
jbell
Apr 18, 2004 09:02 PM
