Few Questions
Old 04-08-2006, 03:02 PM
TurboEH2's Avatar
Default Few Questions
Ok, I already have a turbo kit on my car.... BUT
I have recently purchased a bigger Precision BB Turbo. On this turbo it has coolant passages, so i do need to run these? Its not like "I dont wanna" run them, just curious if itll kill the turbo, and should i start planning out how imma run em.
Also which runner is best for a pyrometer gauge?
Thanks for the help guys
Old 04-08-2006, 03:32 PM
Zakar's Avatar
yes run the lines.. its easy and is nothing but benificial
just run it in series with the coolant lines that flow through your intake..
Old 04-08-2006, 07:01 PM
Soccerking3000's Avatar
Default Re: (Zakar)
you need to run them, the oil lines on those turboes are just to lubricate the ball bearings, not to cool, like on straight oil cooled/lubricated turboes. The BB ones use the oil the lube it and the water to cool it, otherwise it will over heat and lead to premature bearing failure amoung other things...
edit: run the pryometer in the #3 runner, it usually runs the hottest
Old 04-08-2006, 07:13 PM
TurboEH2's Avatar
Default Re: (Soccerking3000)
cool thanks guys
h22 civic
04-27-2011 07:27 PM
jfruauff
05-19-2007 03:20 PM
JuiCe57
08-10-2005 07:19 PM
COLORPROS
02-10-2005 01:31 PM
11psiTurboSI
12-21-2004 04:52 PM
Quick Reply: Few Questions
