As far as AC
Old Jun 8, 2004 | 12:37 PM
  #26
CRX T-Si's Avatar
Default Re: (DaX)
Yo DaX, why don't you just sent the mani to Jet-Hot or some header coating place and get it ceramic coated to reduce heat??
Those wraps are not cheap ya know and the ones from Jet-Hot has a lifetime warrenty on new products being coated.
As for the A/C thing, well I don't remember the last time I enjoyed a cool breeze in my CRX except in the winter of cause.
It was Turbo or A/C for me and guess which I choose......
Old Jun 8, 2004 | 01:04 PM
  #27
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Yo DaX, why don't you just sent the mani to Jet-Hot or some header coating place and get it ceramic coated to reduce heat??</TD></TR></TABLE>
The wrap is for the upper radiator hose. Without any modification, the upper radiator hose would lay directly on the manifold. I may get my manifold coated later on down the road, but I want it in my car so bad now.
Here is a picture of a sidewinder installed [EDIT: THIS IS NOT MY CAR] so you'll know what I'm talking about. Look at the upper radiator hose, mine will be exactly like that but also wrapped:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Those wraps are not cheap ya know and the ones from Jet-Hot has a lifetime warrenty on new products being coated.</TD></TR></TABLE>
The wrap is only $12 for a 12 ft length...pretty cheap in my book.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">As for the A/C thing, well I don't remember the last time I enjoyed a cool breeze in my CRX except in the winter of cause.
It was Turbo or A/C for me and guess which I choose......</TD></TR></TABLE>
I live in GA...AC is a must. This is why I went with the sidewinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonnybravo &raquo;</TD></TR><TR><TD CLASS="quote">Keep us up on it because I'm gonna have this issue to deal with soon as well. Also, where do you plan to relocate your radiator overflow tank?</TD></TR></TABLE>
I have already relocated my radiator overflow tank. Here are some pictures:
I use 1/4" ID fuel hose to go from the radiator to the overflow tank. Right now I have it routed directly, but I am going to re-route it around the side of my engine bay so it doesn't have to cross the manifold. I had to cut the fat tip off the neck on the reservoir to get the fuel hose on. It still took some encouragement. I am using hose clamps on both ends to hold it secure. For mounting of the tank, I used the stock mounting bracket and using only the top bolt to secure it [the hole in the bottom of the bracket has nowhere to mount, but with the top bolt in it's very sturdy...doesn't vibrate against the frame], mounted it where you can see where one of the brackets for the wiring harness used to be.
I'll be sure to keep you posted...just look out for the writeup...I'll make a new thread for it.
Modified by DaX at 5:59 PM 6/8/2004
Old Jun 8, 2004 | 01:08 PM
  #28
CRX T-Si's Avatar
Default Re: (DaX)
I thought you were going to wrap the entire manifold and stuff that's why I said it's expensive.
Old Jun 8, 2004 | 01:13 PM
  #29
DaX's Avatar
DaX
Loved
Community Favorite
Nope, just the radiator hose.
  #30
shadow103rd's Avatar
Default Re: As far as AC (Atheist)
My AC Works great. I havent wrapped it with anything.
and I live in New Mexico where it gets really really hot 100+ days all summer
but do get a recharge
JON
Old Jun 8, 2004 | 01:47 PM
  #31
blackdude's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">
What type of manifold is that, and were did you get it from.
Old Jun 8, 2004 | 01:51 PM
  #32
FOrSfEd's Avatar
Default Re: (blackdude)
sidewinder, http://www.lovefab.com
Old Jun 8, 2004 | 02:19 PM
  #33
blackdude's Avatar
does coolant leak from that radiator hose with that metal tube
Old Jun 8, 2004 | 02:33 PM
  #34
DaX's Avatar
DaX
Loved
Community Favorite
No, it should not when using metal hose clamps.
IF you're talking about on that particular setup, I don't know...it isn't my car. I'm using worm drive hose clamps.
Old Jun 8, 2004 | 03:01 PM
  #35
Smooth-GSR's Avatar
Default Re: (DaX)
Anyone use that home depot stuff? The stuff made for pipes or home ducting? Its much cheaper than the DEI stuff...
Old Jun 8, 2004 | 04:04 PM
  #36
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (Smooth-GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smooth-GSR &raquo;</TD></TR><TR><TD CLASS="quote">Anyone use that home depot stuff? The stuff made for pipes or home ducting? Its much cheaper than the DEI stuff...</TD></TR></TABLE>
I doubt it has the heat rejecting capabilities that the DEI stuff or the McMaster stuff has.
Old Jun 8, 2004 | 04:44 PM
  #37
Smooth-GSR's Avatar
Default Re: (DaX)
I was looking at the DEI cool tape, its aluminum bonded with woven fiberglass. Not sure if it makes that much of a difference compared to the home depot stuff that looks very similar. But then again, most peeps here have spent enough that a few extra bucks for the DEI stuff isn't too bad...
Old Jun 8, 2004 | 08:32 PM
  #38
VacantBanana's Avatar
Default Re: As far as AC (shadow103rd)
hey Atheist u forgot to bitch at the other 2 people who said the same thing i did, just trying to keep u on top of things, maybe u just forgot, dont worry i understand
bk11383
Aug 29, 2005 11:57 PM
v.i.gsr
Nov 22, 2004 10:13 AM
boostdGS
Jul 21, 2003 12:31 PM
speedymon
Aug 29, 2002 06:42 PM
