As far as AC
Old Jun 7, 2004 | 08:35 AM
Atheist's Avatar
Default As far as AC
The AC line in my car is right by the turbo, its rapped but still its very close. It blows pretty warm, but it hasnt been recharged for a while. Will it ever blow cold, or because its so close to the hot *** turbo will it always be warm?
I'm asking becuase I still havent sold my other car so I cant get a beater to drive daily and its hot as hell in the afternoons.
Modified by Atheist at 11:50 PM 6/8/2004
Old Jun 7, 2004 | 08:54 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: As far as AC (Atheist)
If its wraped it should get at least a little cold. Mine is still cold! I would say get a recharge My .02$$$
Old Jun 7, 2004 | 09:17 AM
Muckman's Avatar
Moderator in Chief
Mine got so hot it actually set my AC line insulation on fire! Boy that was scary. But I wrapped the line with this hose thermal wrap from DEI. Now my AC is cold again.
Old Jun 7, 2004 | 09:23 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: As far as AC (Muckman)
DEI? Show me where you got this stuff...I know I'm going to need it.
Old Jun 7, 2004 | 09:32 AM
FOrSfEd's Avatar
Default Re: As far as AC (DaX)
summit sells it. I wrapped my lines with that also. It's good up too 2000 ambient temps, which is as long as it dosen't touch the wrap it should be good.
Old Jun 7, 2004 | 11:49 AM
Muckman's Avatar
Moderator in Chief
http://www.designengineering.com/
Got mine from Summit.
Old Jun 7, 2004 | 01:38 PM
BodyKits NW's Avatar
Which one did you order from summit. Part number please
Old Jun 7, 2004 | 01:43 PM
FOrSfEd's Avatar
Default Re: As far as AC (BodyKits NW)
Andy it depends on how much you want>
the 12x12 sheet is THE-13500 $9.88
the 12x24 sheet is THE-13575 $17.88
Old Jun 7, 2004 | 02:01 PM
Default Re: As far as AC (FOrSfEd)
Aight, I will have to see how much I need, but I'll probably just get the larger sheet to be on the safe side. I need to wrap all my AC lines.
Old Jun 7, 2004 | 06:24 PM
Muckman's Avatar
Moderator in Chief
DEI-010405
Only issue with it is that its kinda big and they dont make a smaller diamter shroud with velcro. $30
Old Jun 7, 2004 | 06:32 PM
Turbo E's Avatar
use regular header wrap and then cover it with aluminum foil tape, you can buy it at home depot in the ducting department.
cheap and effective
Old Jun 7, 2004 | 07:27 PM
Smooth-GSR's Avatar
Default Re: (Turbo E 604)
I've heard of people just using the aluminum tape stuff from home depot etc, but the stuff I found had no heat rating on it, not sure if it could withstand engine bay heat....
Old Jun 7, 2004 | 08:02 PM
VacantBanana's Avatar
Default Re: (Smooth-GSR)
take the ac out , lose 70 ponds and gain a hp or two
Old Jun 7, 2004 | 08:11 PM
Atheist's Avatar
Default Re: (VacantBanana)
Thanks for all of the good info guys. Im going to recharge my AC tomorrow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VacantBanana &raquo;</TD></TR><TR><TD CLASS="quote">take the ac out , lose 70 ponds and gain a hp or two </TD></TR></TABLE>
Thanks for the bright idea captain. Do you really think that, given the text in my original post, I would concider taking it out if itd work? No. Becuase its hot, and 70lbs doesnt mean **** to me when Im hot. When Im hot, being cold is the only thing that matters. Don't be a bandwagoner, 'delete AC, delete ps' etc etc. Useless post.
Old Jun 7, 2004 | 08:19 PM
Default Re: (Atheist)
see now if u took out the ac youd sweat more also, and get lighter, ud be on ure way to 9 sec 1/4 miles man. jesus taking crap so seriously, easy up buddy i was joking around, and i didnt join a "bandwagon" because ive never ever seen take post.
Old Jun 7, 2004 | 09:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd &raquo;</TD></TR><TR><TD CLASS="quote">Andy it depends on how much you want&gt;
the 12x24 sheet is THE-13575 $17.88</TD></TR></TABLE>
That stuff seems to be the best since it not only withstands a lot of heat, but its got a self adhesive backing. I'll probably use that to cover my AC lines.
Thanks everyone!
Old Jun 7, 2004 | 11:35 PM
jonnybravo's Avatar
Curious, do you guys think this stuff will work on my radiator hose since I'm going to be using a Lovefab Cast Sidewinder?
Old Jun 8, 2004 | 05:23 AM
DaX's Avatar
DaX
Loved
Community Favorite
I am using a lovefab welded sidewinder. Here is my plan for the radiator hose [I'm going to do a full writeup with pictures when I do it]:
Stock hose with a piece of 1.25" OD stainless steel pipe in it where it crosses the manifold. I'm also going to wrap it in some heavier duty wrap than this stuff that I got from McMaster-Carr. The PN is 9379K93 and it's about $13 for a roll of it that is 12 feet long [it's 3" wide and 1/2" thick]. It's heat rating is -50*F to +2300*F ...I think it will work. I also bought a roll of aluminum tape to essentially make it one solid piece and tape over the cracks. Hope this helps.
Old Jun 8, 2004 | 06:22 AM
FOrSfEd's Avatar
Default Re: (DaX)
Thanks Dax i might have to try that since the temp rating is higher. Do you know if that is ambient temp rating or actual touch temp rating?
Old Jun 8, 2004 | 07:00 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (FOrSfEd)
Here is what the site says about it:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">High-Temperature Pipe and Tube Wrap
• Temperature Range: -50° to +2300° F
• Heat Flow Rate: 0.25 Btu/hr. x in./sq. ft. @ 75° F
This durable wrap not only withstands extreme heat, it also has excellent sound absorption and resists tears. Made of white alumina-silica based ceramic fibers with an aluminum jacket, it's unaffected by hydrocarbons and water and resists most chemicals. Use this UV-resistant material indoors and out.</TD></TR></TABLE>
I'm sure the aluminum jacket rejects most of the radiation heat, but after feeling the silica insulation, I'm sure it will resist plenty of contact heat. Just to be safe I'm using that piece of stainless steel tube where it crosses the manifold. I think this combination of stuff will work quite well.
Old Jun 8, 2004 | 10:43 AM
jonnybravo's Avatar
Default Re: (DaX)
Keep us up on it because I'm gonna have this issue to deal with soon as well. Also, where do you plan to relocate your radiator overflow tank?
Old Jun 8, 2004 | 11:03 AM
FOrSfEd's Avatar
Default Re: (jonnybravo)
When i had my sidewinder I used a 88-91 crx overflow and put it right in front of the ps pulley.
Old Jun 8, 2004 | 11:41 AM
Atheist's Avatar
Could someone please tell me what AC type my 94 accord has? I need to buy a recharge kit and cant find the helms. Its basically too damn hot too look even.
Old Jun 8, 2004 | 12:09 PM
97ITR60's Avatar
take it out you don't need it
Old Jun 8, 2004 | 12:14 PM
2000GSRT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Atheist &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all of the good info guys. Im going to recharge my AC tomorrow.
Thanks for the bright idea captain. Do you really think that, given the text in my original post, I would concider taking it out if itd work? No. Becuase its hot, and 70lbs doesnt mean **** to me when Im hot. When Im hot, being cold is the only thing that matters. Don't be a bandwagoner, 'delete AC, delete ps' etc etc. Useless post. </TD></TR></TABLE>
Lose the AC. If you get hot, just buy a slurpee
