Faint Gas Smell
Old Aug 8, 2009 | 04:16 PM
Dubs13's Avatar
Default Faint Gas Smell
There's a faint smell of gasoline in my oil whenever I check it. Why would tht be? I have a boosted B18B1 with stock internals running 7psi. Walboro fuel pump and 440cc injectors. Any takers?
Old Aug 8, 2009 | 04:39 PM
B16Drag's Avatar
Default Re: Faint Gas Smell
Not sure what to make of it but I have a slight smell as well... I just assumed it was due to the volatile chemicals after gas combustion.
Old Aug 8, 2009 | 05:19 PM
93supercoupe's Avatar
let me guess, the car isnt tuned?basemap? Its too rich.Probably washed the rings already.
Old Aug 8, 2009 | 06:46 PM
m R g S r's Avatar
Mine smells the same. it's probably from blowby on a high mileage stock motor. No biggie just change the oil frequently. My LS motor is beaten daily and still pulls strong/starts right up.
Old Aug 8, 2009 | 08:53 PM
Dubs13's Avatar
Actually it's dynotuned on Hondata by a well renowned tuner in my area. The motor has 80k on it and was barely driven and NEVER beaten while it was untuned. Do you still think I washed the rings or could it just be normal blowby?
Old Aug 9, 2009 | 09:30 AM
Dubs13's Avatar
I should also mentioned that it bogs a little when cold on 5% throttle but goes away if you press the pedal more. Also, the distributor sounds like it has a rock bouncing inside of it when it's cold which I'm assuming is caused by a loose rotor. That and both the check engine light and SRS light come on every other time that I drive it but go away if I turn it off and back on.
BlackCivicEX
Aug 22, 2018 11:09 AM
sevenfc
Sep 2, 2009 01:03 PM
twistedgsr
Mar 19, 2007 08:31 PM
EJ8 GSR-T
Feb 17, 2007 07:48 AM
puertoroc7976
Oct 13, 2006 07:30 AM
