Factory flywheel with 450 + hp?
Old May 28, 2002 | 07:02 PM
Ltech's Avatar
Default Factory flywheel with 450 + hp?
Anyone in here with 450 + hp? Any problem so far? If you run 11's or faster , Will the track official make you take the tranny for inspection( )? to see if you run aftermarket flywheel.
jason phan \
[Modified by Ltech, 4:03 AM 5/29/2002]
Old May 28, 2002 | 07:24 PM
92JDMSiR's Avatar
Default Re: Factory flywheel with 450 + hp? (Ltech)
this isn't based on experience but I think that the OEM would be able to take the added hp. it's not so much as the horsepower that would hurt it but the clutch. but in the end it still goingt o depend on the horsepower for what clutch application your are goingt o use. my M flywheel holds up great and I'm at 309 at the wheels. there's a big difference between 309 and 450 hp. the chromoly flywheels tend to develop spider cracks. a lightened OEM is definitely not a good idea because they are prone to explosion. I can't imagine what will happen with around 450 on tap.
Old May 28, 2002 | 07:39 PM
tmg's Avatar
tmg
Default Re: Factory flywheel with 450 + hp? (92JDMSiR)
i agree. i'm not running 450+ but the oem quality is impressive when least expected. i'd stick with the factory flywheel.
Old May 28, 2002 | 07:41 PM
paulzy's Avatar
Default Re: Factory flywheel with 450 + hp? (themi6group)
NHRA rulebook demands an aftermarket SFI approved flywheel for anything 11.99 and quicker
Old May 28, 2002 | 08:11 PM
Ltech's Avatar
Default Re: Factory flywheel with 450 + hp? (Slow_ass_4dr)
Basically I'm looking for something to hold 450 + hp. Everyone I talked to run stock flywheel with 200-350hp range with no problem. On last thing, who make flywheel that can hold the power I want and weight around 12-15 pounds. I dn't want no light weight flywheel. By the way, I;m going for clutchnet clutch.
jason phan
Fnix
Transmission & Drivetrain
Sep 29, 2010 08:37 AM
mtownek9
18
Oct 23, 2007 08:48 AM
93sivtec
Apr 22, 2007 08:57 AM
cr-x si
Dec 11, 2002 11:40 PM
