F22 Turbo
Old Feb 10, 2005 | 05:01 PM
uictony's Avatar
Default F22 Turbo
im in the works of a budget boost f22 project right now. for my setup i plan on using dsm parts to make this happen. i plan on using
dsm manifold
dsm t25 turbo
dsm B.O.V. (fist gen)
stealthmode performance oil line kit.
either dsm SM intercooler or a FM from Johnnyracecar.com
apexi turbo timer
slowboy racing boost controller.
that is what i have so far. what do you guys think. anything that i am missing,overlooked, change?
what about fuel and ignition, these two i am not sure on and any info about this would be great.
Old Feb 10, 2005 | 05:14 PM
JDM.Accord's Avatar
Default Re: F22 Turbo (uictony)
Well if you're on a budget you can skip the turbo timer as they are not necessary if you have a little patience A wastegate would help too. And obviously you'll need some engine management. For your setup the hack would work or you can go uberdata
Old Feb 16, 2005 | 06:09 AM
uictony's Avatar
Default Re: F22 Turbo (JDMAccord2nr)
well maybe i should of mentioned that my car was a 96 Prelude with a f22. its obdII and if i remeber correctly that the hack and uberdata are for obdI. thanks for the info.
Old Feb 16, 2005 | 06:35 AM
notoriousB's Avatar
the hack will work fine for OBD2. well maybe "fine" is a stong word. it will work.
what f22 is in a 96 lude? If it's an F22B the DSM manifold will not work. The ports on the head will not line up with the mani. F22A will work.
Old Feb 16, 2005 | 06:36 AM
AccidentproWn's Avatar
the hack is for anything uberdata is for obd1 get a conversion harness and a p28 and use uberdata
Modified by AccidentproWn at 5:34 PM 2/16/2005
Old Feb 16, 2005 | 08:10 AM
uictony's Avatar
Default Re: F22 Turbo (AccidentproWn)
the prelude is a f22A so the manifold will work so thats good. thanks for the info about engine management.. i will definately look into that. is there anything else that i am missing or am i good2go. thanks..
korney
Jan 17, 2007 04:17 PM
jacob_kohler
Mar 17, 2005 07:47 AM
SlammedCD7
Jul 1, 2004 06:51 PM
kjg8erz8
Apr 25, 2004 09:48 PM
accordtunerx
Apr 4, 2004 09:35 AM
