air/fuel ratio guage install on b16
im just bout to finish puttin my motor back in after rebuildin the block and boring it to 84mm. i talked to my tuner and he siad u can start it and if it doesnt run lean u can break in the motor b4 u get it tuned.. so i need to find out how to install the guage properly. i had it b4 but it wasnt hooked up right or my sensor was bad so i got a new sensor but dnt knw hwo to install it..... there are 4 wires on the sensor.. does anyone know how to do this? im sure others have done it on there b16's
Re: air/fuel ratio guage install on b16 (lovey408)
hopefully you are talking about a wideband gauge. if not i wouldnt risk my fresh build on a standard narrowband. there are plenty of write-ups on the install check out the FAQ and there should be an ECU pinout thread as well.
Re: air/fuel ratio guage install on b16 (1fastEK9)
yeah it connects to the actual sensor. there are 2 wires. so wat one goes to the green and wat ones goes to the other one?
sins
09-28-2009 10:00 AM
