f22 half ass built block
Old Sep 25, 2002 | 01:28 PM
Howitt's Avatar
Default f22 half *** built block
how would a f22a6 hold reliably if it was block posted and had after market rods in it with stock pistion and new gapless rings, I was thinking in the range of 12-14 psi, but I thought I would give the idea up to the FI guys
Old Sep 25, 2002 | 02:14 PM
fastludeh22's Avatar
Default Re: f22 half *** built block (Howitt)
i dont know what you mean by the block posted. also im not sure about the f22, but h22 ring lands are the weak part of the engine. if you only have money for one, get pistons and see if h22 rods will work...or save a little more and get pistons and rods...there not that much compared to a full build
Old Sep 25, 2002 | 03:05 PM
rOby's Avatar
Default Re: f22 half *** built block (93ludevtec)
can t just use aftermarket pistons in an h series block. it needs to be sleeved to do that. you should be able to get by w/ posting and stock pistons..but since pistons are weak link...save up.
Old Sep 25, 2002 | 03:07 PM
inspyral's Avatar
Sonny's block posts:
[Modified by inspyral, 4:07 PM 9/25/2002]
Old Sep 25, 2002 | 03:28 PM
Kevin's Avatar
I think hes talking about drilling holes in the block and inserting posts that secure the sleeves to the sides of the block. Larry at endyn had some pics of this up on his old forum. I think its a pretty good idea to stop the sleeves from shifting. The problem might be the actual strength of the sleeves though. I dont think 12-14 psi would create as problem as long as its tuned right... Although im merely quesstimating here.
michaelprice83
Feb 1, 2009 07:27 AM
crazes
17
Dec 30, 2008 01:28 PM
Prudz_lude
May 21, 2007 12:50 PM
three6t
Dec 22, 2004 11:25 AM
Maddox
Jun 6, 2004 08:53 AM
