F22 with boost???
Old Aug 5, 2007 | 02:23 PM
BIG T's Avatar
Default F22 with boost???
i was just wondering if f22's are ok for boost considering they have low compression. Or are their cylinder walls extremely thin or something??
Is there anything else that i need to know about them before i turbo??
Old Aug 5, 2007 | 04:58 PM
1cpu's Avatar
Default Re: F22 with boost??? (BIG T)
theres a f22 turbo thread that should give u all ur info
Old Aug 5, 2007 | 05:12 PM
redzcstandardhatch's Avatar
something different
Default Re: F22 with boost??? (1cpu)
yeah they are fine....no detonation (with a good tune), and a decent kit, and they make great power.
Old Aug 6, 2007 | 05:59 AM
twkdCD595's Avatar
Default Re: F22 with boost??? (redzcstandardhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">yeah they are fine....no detonation (with a good tune), and a decent kit, and they make great power.
x2.
f22's react pretty well to moderate amounts of boost from my experience as well. lower compression, oe sleeves are iron, etc... just need to make sure to use quality fuel management and have it tuned.
the only downfall of the f22 IMO is the typical oe honda pistons/ weak ring landings can or will crack from detonation at almost any power level (hence why good tuning is so important)... that said, you would be very pleased/ suprised at how well the f performs boosted.
Old Aug 6, 2007 | 10:43 AM
raceACCORDingly's Avatar
stock low CR, iron liner sleeves, 2.2L FTW!
F22a heads flow decently from what ive read, f22bx are a diff story.
Old Aug 6, 2007 | 03:12 PM
something different
Default Re: (raceACCORDingly)
f22a1 heads are incredible. best honda head i've ever seen.
on 11-12 psi i'm making somewhere near 350-400 whp, and similar torque (judging by what others have done, and my injector duty cycle, maxing 700 cc's). bottom end is stock, head has springs and a cam (both bisimoto)
Old Aug 7, 2007 | 12:33 PM
fast93accord's Avatar
Default Re: (redzcstandardhatch)
I have a turbo F22a. It F-N flies on low boost 12-15psi on the street. I went 12.5 on 15psi a bad 60foot and misfiring... Like stated the OEM pistons are junk...and will break...
Old Aug 7, 2007 | 12:41 PM
twkdCD595's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceACCORDingly &raquo;</TD></TR><TR><TD CLASS="quote">stock low CR, iron liner sleeves, 2.2L FTW!
F22a heads flow decently from what ive read, f22bx are a diff story.</TD></TR></TABLE>
From what I know, the f22a6 head is the specific head to which you refer with the big flow numbers everyone drools over, but the other 2 f22a (a1/ a4) heads are nothing special... from what I have seen.
Same with the f22b1 head... it flows quite well (better than people think) but the f22b2 head is nothing special.
Old Aug 7, 2007 | 01:20 PM
something different
Default Re: (twkdCD595)
i'm really impressed with the head on my f22a1 ..way better than the f22b2 i saw
Old Aug 7, 2007 | 01:27 PM
twkdCD595's Avatar
I dont want to get someone elses thread off track but I would be curious to know what specifically impressed you and in what way the a1 seemed better to you?... it is hard to find information so I try to collect as much as possible from any sources I can so if you can direct me to any I would greatly appreciate it.
Though as I stated above the b2 head specifically is nothing special and I am not impressed with it... the b1 head is much better from the information I have seen and my personal experience with both.
Modified by twkdCD595 at 4:39 PM 8/7/2007
Old Aug 7, 2007 | 01:42 PM
something different
well, i'll try to get some pictures, but mainly, the ports are huge and seem really idealy shaped (intake mainly, exhaust isnt bad, but nothing too out of the ordinary for honda)
the intakes are absolutly amazing from the factory... more-so than any other factory head i've worked with (of any manufacturer)..
i'd love to see the b1 head next to the a1..i bet they are very similar
Old Aug 7, 2007 | 06:17 PM
BIG T's Avatar
how is the F22B the dual cam motor
Old Aug 8, 2007 | 01:07 PM
BIG T's Avatar
BUMP
Old Aug 8, 2007 | 03:05 PM
what is different about the f22a6 compared to the f22a1/2 heads? aside from the butterfly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIG T &raquo;</TD></TR><TR><TD CLASS="quote">how is the F22B the dual cam motor</TD></TR></TABLE>
if you put an h23 head on f22 block, you basically have a jdm f22b dohc motor.
Old Aug 9, 2007 | 11:53 AM
BIG T's Avatar
Default Re: F22 with boost??? (raceACCORDingly)
this doesn't answer my question??
Old Aug 9, 2007 | 12:27 PM
something different
what is your question? "how is it?"
its fine.
Old Aug 9, 2007 | 04:57 PM
singlehead's Avatar
h22 head+turbo=bad a$$ f22
Old Aug 9, 2007 | 11:35 PM
91accordexr33's Avatar
JDM F22B's are good motors. Lil pricer to find and have slightly higher copression (i think 9.0:1)
Im runnin a f22a4 @ 10psi for 2 years with no problems. on a 16g im guessin im makin about 220-240 wheel
Old Aug 10, 2007 | 07:32 AM
d112crzy's Avatar
F22B DOHC has a cr of 9.2.
F22B2 head flow numbers
http://www.accordinglydone.com...14075
F22A1 head(borrowed from HondaFan81 on cb7tuner.com)
Old Aug 10, 2007 | 11:13 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BIG T &raquo;</TD></TR><TR><TD CLASS="quote">this doesn't answer my question??</TD></TR></TABLE>
its basically an h23 with a tad lower CR, smaller bore, less torque, same hp.
Old Aug 10, 2007 | 11:14 AM
Default Re: (d112crzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d112crzy &raquo;</TD></TR><TR><TD CLASS="quote">F22B DOHC has a cr of 9.2.
wow thats pretty big diff on the intake side. but the b2 exhaust ports flow better?.. wow
wonder if theres much a of a diff between the f22b1 and b2 head flow
Old Aug 10, 2007 | 11:51 AM
twkdCD595's Avatar
wonder if theres much a of a diff between the f22b1 and b2 head flow</TD></TR></TABLE>
I have yet to see any good comparison of flow numbers between the b1/b2 heads, but as you say I would be interested to see how the b1 numbers would play into this. The b1 head will most definately outflow the b2 since the b1 has larger valves but I am curious by how much.
also I have yet to see the a1, a4, and a6 heads flowed and compared side by side... anyone wanna loan me a flow bench for a few days.
Modified by twkdCD595 at 3:08 PM 8/10/2007
Old Apr 22, 2009 | 10:33 PM
keoni96764's Avatar
well if your still wondering from what i heard the a6 has a little better cam but thats it head wise and the intake mani is better.
poormans_typer69
Jul 22, 2008 03:07 PM
SiTR
Jan 11, 2007 10:00 PM
Toroke
Apr 6, 2006 04:02 PM
9341civic
Apr 2, 2005 12:16 AM
Corinthians
Sep 12, 2004 11:04 AM
