F.A.S.T. standalone tps question
Old May 23, 2006 | 08:40 AM
Ntense90crxsi's Avatar
Default F.A.S.T. standalone tps question
I bought a FAST system used from another honda guy and he was using a ford throttle body, I want to keep my honda tb and was wondering if the tps will work with that system?
Old May 23, 2006 | 09:05 AM
DaveF's Avatar
Default Re: F.A.S.T. standalone tps question (Ntense90crxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ntense90crxsi &raquo;</TD></TR><TR><TD CLASS="quote">I bought a FAST system used from another honda guy and he was using a ford throttle body, I want to keep my honda tb and was wondering if the tps will work with that system? </TD></TR></TABLE>
it should. usually have to set closed tps voltage and w.o.t. voltage in the ems, so it knows what is what. (also used a ford tb with my speed pro)
Old May 23, 2006 | 09:17 AM
trickeng's Avatar
Default Re: F.A.S.T. standalone tps question (dturbocivic)
they are both 0-5v TPS's, so yes it will work. you may need to recal in the ems but most likely it will be really close just by wiring it in place of the ford one.
Old May 23, 2006 | 10:45 PM
Default Re: F.A.S.T. standalone tps question (trickeng)
what ford tb's is everyone using, should I get one?
Old May 24, 2006 | 04:56 AM
DaveF's Avatar
you can use the 88-93 styl tb i belive it has a standard square flange/4 bolt pattern.
Old May 24, 2006 | 07:25 AM
trickeng's Avatar
that is correct.
Old May 24, 2006 | 11:14 AM
sweetness, well I may call on you FAST guys again for some help around the standalone and tuning, thanks for the info.
xparalandrax
Oct 28, 2007 08:31 AM
Tonydalude
May 14, 2005 02:22 PM
Audi RS4
Sep 17, 2004 09:52 AM
dwchkypmp20
Feb 21, 2004 09:00 AM
lilbill3554
Jan 28, 2004 07:39 PM
