On a T3T4 turbo, how much boost can I safely run on a GSR stock sleeves w/forged internals?
476 whp / 323 tq @ 17 PSI
Garrett T3/T4e 57trim .63ar turbo, victor x manifold, ramhron manifold, and 3'' downpipe to 3'' exhaust on a stock sleeved GSR with new bearings (main and rod), Eagle Rods, CP 9.0:1 pistons, and 00-01 ITR cams, HOW MUCH BOOST CAN I SAFELY RUN?? this is my everyday driving car so i was looking at 12psi. i know i should be asking how much wheel horsepower but given the specs of the turbo and my set-up, i would think you guys can translate the max power to the spring i should run. im gettin a 38mm tial wastegate and need to know asap what kind of spring i will need to the max and safely. i would like to run as much power as possible but on pump91 gas, im limited. thanks for your inputs!
<FONT SIZE="3">WITH A 81.5MM BORE ON STOCK SLEEVES, WILL 350WHP STILL BE A RELIABLE SET-UP??</FONT>
Modified by JDM turbo DC at 12:17 AM 3/7/2006
Re: On a T3T4 turbo, how much boost can I safely run on a GSR stock sleeves w/forged internals? (JDM
I think you will be fine at 12psi, I'm building a similar set-up and I plan on running around 14psi on a daily basis. Get it tuned to like 15psi, and drop the boost down a little bit for daily driving. With good tuning the stock block/sleeves can handle alot more than 15psi, so I would stay start at 10-12psi and work your way up to a comfortable/stable level. My guess is that you'll make around 320-350whp at 10-12psi with proper tuning
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">****, i'm going to run stock and push 11-12psi ON A 60TRIM...............you're safe for 400whp and around 18psi easily
well i rele need the car to be reliable, so now im thinkin 14psi not quite 18psi.
Re: (JDM turbo DC)
I say 18psi. What are u using for tuning? Remember u can set it low for everyday then raise it at the track or the.... you know. for a boost controller
Man U FTW
again to put this in perspective....i'm going to run 10psi daily on the 60 trim.....you can afford to push it more!! The sleeves are good for 550+whp and it has been proven many times!
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">again to put this in perspective....i'm going to run 10psi daily on the 60 trim.....you can afford to push it more!! The sleeves are good for 550+whp and it has been proven many times!</TD></TR></TABLE>
thanks, bump for more opinions!
I've quit using this account
http://forums.evans-tuning.com...=2598
650 WHP
28 psi
stock sleeves
you will be fine.
it is all in the tune.
get someone that know how to tune it and you will be good to go
650 WHP
28 psi
stock sleeves
you will be fine.
Re: (llewsirc)
timing is critical if ur doin high psi on stock sleeves... i would go with llewsirc and say that get someone with a god tuning reputation. other thatn that i would say no more than 10.
Location: The Village Hidden in the Leaves: Seattle, WA
i'm sure you can go beyond 12psi. but like to be on the safe side, go with that. do what you feel is most comfortable. personally, i would just go one bar.
Re: (undercoverdc2)
well i know the stock sleeves can handle 500+ but for how long? i need my motor to hold strong with the investment im having for my daily driver. im pretty much aiming at minimum 350whp and maximum 400whp
Re: (JDM turbo DC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC »</TD></TR><TR><TD CLASS="quote">well i know the stock sleeves can handle 500+ but for how long? i need my motor to hold strong with the investment im having for my daily driver. im pretty much aiming at minimum 350whp and maximum 400whp</TD></TR></TABLE>
my point was that stock sleeves can handle ALOT more power then 350 - 400 WITH A GOOD TUNE
you will be fine at the power levels you are wanting.
hell im making 300 on stock d series sleeves
its all in the tune
its all in the tune
Re: (llewsirc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llewsirc »</TD></TR><TR><TD CLASS="quote">
its all in the tune </TD></TR></TABLE>
im taking my car to be tuned at Churchs Automotive withe crome pro
Re: (JDM turbo DC)
oh yea, i just found out that im gunna bore the sleeves. On a good tune, will the sleeves still handle up to 350whp on a 81.5mm bore on stock sleeves?
Modified by JDM turbo DC at 12:11 AM 3/7/2006
Re: (JDM turbo DC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC »</TD></TR><TR><TD CLASS="quote">oh yea, i just found out that im gunna bore the sleeves. On a good tune, will the sleeves still handle up to 350whp on a 81.5mm bore on stock sleeves?</TD></TR></TABLE>
Re: (JULEZAMAZING212)
for a reliable daily driver with stock sleeves at 81.5mm bore and forged internals, i'm now aiming for 300whp min 350whp max, i just dunt feel comfortable boostin the stock sleeves to the limit. i cant take chances.
