a/f ratio change?
Old Dec 19, 2008 | 02:15 PM
turbo-crx's Avatar
Default a/f ratio change?
by adding a victor x intake mani, how much would that change the a/f ratio. say it was 11.5a/f before the manifold change. thanks.
Old Dec 20, 2008 | 08:03 AM
TheShodan's Avatar
Moderator
None. it is irrelevant to the air/fuel ratio.
Old Dec 21, 2008 | 04:21 AM
turbo-crx's Avatar
What paramaters does it change in the tune? I figured with the more air it brings in, it would change a/f.
Old Dec 21, 2008 | 04:46 AM
blackeg's Avatar
hmm interesting. i also would have figured that adding the victorx will help the motor breathe better, and consequently lean the afr because now more air and the same amout of fuel.
i noticed a change in afr a few years ago for example going from a gsr cam to a b16 cam on a mid 300hp setup. afr richened up around 2 or 3 tenths because the motor wasnt flowing as much air decreasing i thought.
is it irrelevant to afr just because it would cause a small increase in the motors ability to flow air??
MooreBoost
Aug 31, 2008 05:52 AM
silentdeath12886
Oct 31, 2006 11:13 AM
Benjithx
Jan 13, 2005 10:08 AM
wasdayuca
Jan 12, 2005 08:36 AM
