F-Max Or Drag Gen 3????
Old Jul 14, 2002 | 10:11 PM
civicRacer95SI's Avatar
Default F-Max Or Drag Gen 3????
I have a 95 si with a jdm gsr motor and I want to put a turbo kit on my motor. I want to use the car as a daily driver and run around 8-10 psi. I have looked at the content of both kits and done a-lot of searching on the subject but I can't figure out which kit would be the best to go with? I was just wondering if any of you guys had experience with either kit, and if you would list the pros and cons of either system. Thank you and I cant wait to become part of the boosted community
Old Jul 14, 2002 | 10:55 PM
supergreenNA1's Avatar
New User
Default Re: F-Max Or Drag Gen 3???? (civicRacer95SI)
i used to work at fmax and have alot of experience with both systems.
PM me.
Old Jul 14, 2002 | 10:57 PM
shadowdawn's Avatar
I would say drag 3.... I don't know if I need to explain why...
otherwise get the fmax without the mf2 junk and get a fmu+inline if thats the case..
Or get either and ditch BOTH their fuel setups and get hondata, aem ems, dfi or other REAL standalone and you'll have a REAL reliable fast car, thats what it comes down to. Your not gonna wanna be boosting more then 5-7 psi on a gsr motor with a fmu or mf2 cause it won't be reliable for long.... higher compression makes things a little more touchy when it comes to detonation since if you don't go standalone there is ALOT of room for detonation and lean conditions to happen which = blown motor....
Old Jul 15, 2002 | 12:42 AM
b18bvudoo's Avatar
New User
Default Re: F-Max Or Drag Gen 3???? (supergreenSol)
dang mike, why are u holding back today?
Old Jul 15, 2002 | 02:18 AM
MiraiZ's Avatar
search search search search search search search search search search search
Old Jul 15, 2002 | 09:01 PM
SIK IN DA HED's Avatar
New User
DRAG3... FMAX is weak. ask people who have had them..
Old Jul 15, 2002 | 09:05 PM
New User
Default Re: F-Max Or Drag Gen 3???? (dlplayboy)
ask me.. i dare u
Old Jul 15, 2002 | 10:49 PM
shane's Avatar
Default Re: F-Max Or Drag Gen 3???? (MiraiZ)
newbie?
civicRacer95SI has been a member for 427 days.
Old Jul 15, 2002 | 11:31 PM
ceemarun's Avatar
Default Re: F-Max Or Drag Gen 3???? (shane)
i installed an f-max on my car and a drag kit, and i gotta say that the f-max was of way higher quality. it seems like they put more r&d into it, whereas drag is sorta like a pre-fab custom kit (sorry if that made no sense). like on the drag mani, theres no way you can easily slip in the bolt for the bottom center hole (i used a stuf and nut and cant get my dipstick in now). f-max fitment was way better. you can order it w/o the mf2 stuff, but i'd take that setup over an fmu and inline anyday (even tho that works). i also didnt like how i had to weld the downpipe to the cat. f-max came with one that had a flange on the other end that was a direct bolt up.
drag oil return is worrisome, and you know what they had to do to cut costs
Old Jul 16, 2002 | 01:35 AM
MiraiZ's Avatar
ask me.. i dare u
yeah ...me too
1JDMDOMINICAN
Apr 19, 2006 10:27 PM
imp0rted1
Feb 27, 2004 01:52 AM
quik sol
Nov 1, 2003 11:39 PM
HRC51
Nov 14, 2002 11:07 PM
PolySquared
Aug 8, 2002 09:54 PM
