a/f gauge wiring help!!!
Old Mar 26, 2003 | 08:19 AM
speester1's Avatar
Default a/f gauge wiring help!!!
i don't want to wire it in the engine bay, rather to the ecu? does anyone know which wire to tap in for 02 sensor for the air/fuel gauge?
95 civic coupe ex
thanks
Old Mar 26, 2003 | 08:23 AM
Superorb's Avatar
Default Re: a/f gauge wiring help!!! (speester1)
it SHOULD be white w/ red stripe, D14 i think if i can remember right... i wired mine to the engine bay, and u must SOLDER connections, or it will be funky like mine was... u dont ahve to solder the leads on the back of the guage tho, i used butt connectors for that.
hope this helps
Old Mar 26, 2003 | 09:08 AM
ITR981002's Avatar
Default Re: a/f gauge wiring help!!! (Superorb)
yup, the correct white wire will be a bit thicker than the other wires around it.
Old Mar 27, 2003 | 09:12 AM
speester1's Avatar
Default Re: a/f gauge wiring help!!! (gothatch)
change of plan! stock 02 sensor have 4 wires: green, white, 2-black. which one is the signal wire?
thanks
Old Mar 27, 2003 | 09:18 AM
ladysman's Avatar
thanks
No need hook it into the O2 sensor. Connect it just like someone told you above. Tap into ECU wire D14 (OBDI) and you are good to go.
Old Mar 27, 2003 | 09:20 AM
Superorb's Avatar
Default Re: a/f gauge wiring help!!! (ladysman)
whe i did d14 it didnt work, so i tapped the white wire on the o2 sensor
Old Mar 28, 2003 | 07:12 PM
speester1's Avatar
i try the white wire d16. doesn't seem to be working correctly. it shows that i'm running lean throught out rpm range.
Old Mar 29, 2003 | 11:05 AM
Superorb's Avatar
D14 is the correct pinout on the ecu, but it didnt work for me, so i wored it to the o2 sensor on the cat
Hondero_PR
Mar 10, 2011 05:24 PM
skata89
Feb 24, 2007 07:41 PM
qazaq
Apr 28, 2006 09:54 AM
yurvn
May 25, 2004 07:30 PM
2K1NBGSR
Aug 3, 2002 12:22 AM
