F*cking manifold has a crack in it.....
Old May 16, 2003 | 09:12 AM
shadowdawn's Avatar
Default F*cking manifold has a crack in it.....
You can barely see it in this pic, but theres a nice crack in between the 4th and 3rd runner (closer to the compressor side)......
Should I invest in an inlinepro manifold? Since full race is out of the question since I love A/C and P/S
Old May 16, 2003 | 09:28 AM
turbod16y8's Avatar
Default Re: F*cking manifold has a crack in it..... (shadowdawn)
what kind of manifold is that>?
Old May 16, 2003 | 09:30 AM
RyanAutry's Avatar
Default Re: F*cking manifold has a crack in it..... (turbod16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbod16y8 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of manifold is that&gt;?</TD></TR></TABLE>
Rev Hard.
shadowdawn's Avatar
Default Re: F*cking manifold has a crack in it..... (RyanAutry)
yea its a rev hard with somewhere over 20k miles on it.
Old May 16, 2003 | 09:35 AM
Rain_man's Avatar
New User
i'd suggest inlinepro if you want the simplest and most durable fix.
Of course you can just get rewelded too.
Smashback's Avatar
I'd invest in $20 worth of welding to fix one of the best cast manifolds ever produced
Old May 16, 2003 | 09:39 AM
shadowdawn's Avatar
Default Re: F*cking manifold has a crack in it..... (PseudoSilvia)
You think a muffler shop could weld that? Or would I have to go elswhere.....
My muffler shop was able to cut the cast iron elbow and reweld the flange on me... just want opinions...
I dont really wanna spend hundreds on a new manifold if I can avoid it for now.
Old May 16, 2003 | 09:43 AM
TurboSedan's Avatar
New User
Have the muffler shop weld it up. Save yourself the $$$$$
Old May 16, 2003 | 05:43 PM
Full-Race Geoff's Avatar
being that you are in NJ, i just came back to town, i may be able to hook u up with someone who can fix that. email me at geoff@full-race.com...
BTW definately DO NOT have just any muffler shop weld that. It is cast and needs a proper prep, weld, and post treatment otherwise it will get worse. Ive seen it happen many, many times.
Old May 16, 2003 | 05:57 PM
lazerus's Avatar
Default Re: F*cking manifold has a crack in it..... (FFgeoff)
mig gun + cast iron = nono
unless you are running nickel wire that is. heh
Old May 16, 2003 | 06:40 PM
BoostedH23a1's Avatar
Default Re: F*cking manifold has a crack in it..... (lazerus)
my rev hard cracked too.. damnit
Old May 16, 2003 | 08:08 PM
CivicSoul's Avatar
Default Re: F*cking manifold has a crack in it..... (BoostedH23a1)
Get A lovefab manifold from Tinker219! I will be posting pics and great praise soon! Nothing Better for the money Anywhere!
Old May 17, 2003 | 08:56 AM
93LSivic's Avatar
Default Re: F*cking manifold has a crack in it..... (CivicSoul)
Take that $100 you won from the h-t meet and put it towards a new one
Old May 17, 2003 | 11:50 AM
shadowdawn's Avatar
Default Re: F*cking manifold has a crack in it..... (93LSivic)
Lol that $100 went towards the swap
Old May 17, 2003 | 04:10 PM
fsp31's Avatar
&gt;&gt;You think a muffler shop could weld that? Or would I have to go elswhere..... &lt;&lt;
I'd just look up a local welding shop. They would probably charge less than $20 and take about 3 minutes. They'll also know a lot more about what they're doing than a muffler shop. With the right rod (can't remember which one right now), they can arc weld that crack just fine even though it is a cast manifold. A muffler shop would never get it right.
Old May 17, 2003 | 04:38 PM
Anubyss's Avatar
Default Re: F*cking manifold has a crack in it..... (fsp31)
Damn I have a Revhard as well. I guess I shouldn't sell the Maxrev manifold just yet.
Old May 17, 2003 | 04:58 PM
igotyofire's Avatar
Default Re: F*cking manifold has a crack in it..... (Anubyss)
is the revhard manifold thats lets u keep AC really not all that strong? is this a common problem? what other manifolds lets u keep your AC ?
Old May 17, 2003 | 08:06 PM
shadowdawn's Avatar
Default Re: F*cking manifold has a crack in it..... (igotyofire)
Drag, maxrev, rev hard and inline pro let you keep A/C I dunno what others..... Rev hards dont usually crack, but **** happens. As far as performance goes Inline pro is probably the best just because of the WG positioning, but rev hards isent bad at all, I think drag's is the worst out of the bunch, but let me know if I'm wrong on that...
Old May 17, 2003 | 08:41 PM
evoeone's Avatar
i MIG weld, but on my cast manifold (i have a VW, my aftermarket turbo mani) my neighbor who works at a machine shop had to TIG to add an external wastegate hole, he used steel rod that had nickel in it, so i know for a fact he told me that, also on vwvortex.com, they say cast and steel has to be welded with a nickel rod, dunno if full nickel, but i guess steel/nickel
Old May 18, 2003 | 02:07 AM
mos's Avatar
mos
Default Re: F*cking manifold has a crack in it..... (evoeone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evoeone &raquo;</TD></TR><TR><TD CLASS="quote">i MIG weld, but on my cast manifold (i have a VW, my aftermarket turbo mani) my neighbor who works at a machine shop had to TIG to add an external wastegate hole, he used steel rod that had nickel in it, so i know for a fact he told me that, also on vwvortex.com, they say cast and steel has to be welded with a nickel rod, dunno if full nickel, but i guess steel/nickel</TD></TR></TABLE>
Steel should be welded with a steel rod. For cast iron, you should be using 99% nickel rod as somebody has already said above.
Old May 18, 2003 | 02:21 AM
XDEep's Avatar
Default Re: F*cking manifold has a crack in it..... (mos)
does the revhard come with any bracing? when the popular ones do crack, do they usually crack towards the 3rd/4rth runners, since the turbo is offset towards them? also, do these things crack only under higher boost or egt's than intended?
the.hamburglar
Mar 9, 2006 10:06 AM
B-Hatchie
Apr 28, 2005 07:38 PM
usdmcivic94
Jan 22, 2005 12:45 PM
allmota1.8
Feb 18, 2004 02:15 PM
yimmy
Jan 12, 2004 08:32 AM
