External oil pump in the way.
What kind of filter can fit over my T3 turbo with a 4" inlet, and also has part of the external oil pump chassis sitting in the middle of the inlet about 1/2 inch in? The external oil pump totally blocks every attempt I have made to put a filter on the turbo. Should I have the turbo system redesigned? Should I see if the external oil pump will be needed and try to get rid of it?
Does anybody have any ideas of a filter method I can use with some insurance I won't cause damage?
The engine is a B18c1 on a CRX Si
https://docs.google.com/uc?id=0BxvO3...nload&hl=en_US
Ok, so as you can see from the photo above that the bolts to the external oil pump doesn't actually pretrude into the inlet at all it just sits there at the opening of the inlet. Any suggestions to what I can use for a filter with the pump still there in the same place? Thank you for advice.
due to your lack of space, you're probably better off with this
http://www.xenocron.com/xenocron-tur...ter-p-222.html
I see you point. I do have a custom oil system. It consist of a belt driven Proflo pump with external Moroso custom oil pan and an external pickup. I bought the car built and have no records of the build once so ever. Maybe if i could eleminate the external oil pump I can install the intake filter system. In most cases, is an external oil pump needed?
Why would an external oil pump be required or suggested to have?
How long would it take to remove the external oil pump?
I really want the oil pump gone if I can do without it but I am not sure if it is required in my setup or not. As you can see the oil pump bolts sit RIGHT THERE at the inlet of my T3 turbo!! I am thinking the oil pump is going to be more trouble than it is worth. But I wanted to know what you guys have to say. I will be running low boost around 10psi or lower because this car is really my daily driver.
I stumbled accross a great thread on honda-tech that explain you can use a part of a t-shirt or a sock and a clamp as a good filter. How hot do T3 turbo inlets get? I should be ok with the shirt idea right as far as not catching the cotton on fire?
Steak84SS
Apr 13, 2004 07:36 AM
