Experienced Tuners : Does this make sense......
Old Jul 24, 2003 | 05:41 PM
b00stedbyFastrax's Avatar
Default Experienced Tuners : Does this make sense......
my current dyno was 477 whp @23 psi(cam gears dialed in0. then dynoed the car at 14 psi and made 320 whp. played with the cam gears and made 342 whp. re-dynoed at 23 psi and the power was 455 whp. thereoically , shouldn't my power go up?
Old Jul 24, 2003 | 06:24 PM
boosted hybrid's Avatar
Default Re: Experienced Tuners : Does this make sense...... (BoostedbyFastrax)
When you are dialing in the cam gears you are dialing in the overlap between the intake and exhaust cam. You want to dial out the overlap in boost so you can retain the maximum amount of compressed air into the combustion chamber and still retain the ability to pull through the residual left from the previous combustion exhaust stroke. If you adjusted your cam gears at a certain psi level, then went to a higher psi level on the same cam gear setting you are more than likely to lose power. If you putting more comressed air into the engine, you might need to allow for a bit more blow-by to reduce the residual from the previous exhaust stroke. Adjusting the cam gears to a certain psi level will guarentee you making power at that psi level, if you are boost higher dont count on the same setting to work.
Old Jul 24, 2003 | 07:00 PM
GOLDBERG's Avatar
Default Re: Experienced Tuners : Does this make sense...... (boosted hybrid)
so what would work good for all boost levels...leaving the setting at 0?
Old Jul 25, 2003 | 03:41 AM
boosted hybrid , thanks for clearing that up for me.
Old Jul 25, 2003 | 03:51 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">so what would work good for all boost levels...leaving the setting at 0?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Adjusting the cam gears to a certain psi level will guarentee you making power at that psi level, if you are boost higher dont count on the same setting to work.</TD></TR></TABLE>
duyfash0
Feb 4, 2010 02:51 PM
ej1252
Nov 10, 2007 04:26 PM
f22abuilder
Feb 16, 2006 06:10 AM
wishwaswiser
Nov 9, 2004 03:51 PM
na200whp
Nov 23, 2003 08:02 PM
