was expecting more than 350hp...
Old Jun 3, 2015 | 01:12 AM
roll8221's Avatar
Default was expecting more than 350hp...
SO, finished my build, broke in the motor, brought it for a tune, and can only get 350 hp out of it... wtf is going on? below is the setup..
-stock sleeves
-Hasport Mounts
-CP Pistons 81.5
-9.5:1 cr
-Manley rods
-ACL bearings
-ARP main and head studs
-Supertech valves, springs, retainers, guides, seals
-Supertech block gaurd
-Clutchmasters 6 puck stage 4
-Aeromotive 340 fuel pump
-AEM fuel rail
-AEM fuel pressure regulator
-ID725 injectors
-Skunk 2 pro intake mani
-Skunk 2 70mm alpha throttle body
-Precision6262 Turbo
-Mishimoto G Line 24.5" x 11.75" x 3" intercooler
-HKS BOV
-OEM gaskets, oil pump, water pump
-Moroso 5.5 qt oil pan
-stock crank, cams
-accel coil
-premium pump gas (no e85 here)
-AEM series 2
Seen similar setups, and even lesser setups put out way more...
any thoughts?
Old Jun 3, 2015 | 03:46 AM
LightningTeg's Avatar
Community Builder
Default Re: was expecting more than 350hp...
GSR? LS? Boost?
Who tuned it?
Old Jun 3, 2015 | 05:13 AM
roll8221's Avatar
Gsr, 22 psi, realstreet orlando,fl.
Old Jun 3, 2015 | 05:17 AM
Community Builder
How does it drive though?
Old Jun 3, 2015 | 06:06 AM
TheShodan's Avatar
Moderator
Dyno could read rather low. or a MAJOR leak somewhere. That is rather uncommon, but as LighteningTeg stated, how does it drive to you?
Old Jun 3, 2015 | 06:11 AM
adam00's Avatar
Did you do a compression or leak down test yet? That's where i would start.
Old Jun 3, 2015 | 06:16 AM
GrantMC2's Avatar
What WG are you running? Not in Spec?
Also, what duty cycle were the injectors at?
Old Jun 3, 2015 | 06:22 AM
AZ_CIVIC's Avatar
The first thing I would do is contact Realstreet and discuss this with them. They should be able to tell you exactly why your setup is making the power it did or what issues you may have, instead of asking people to guess.
Old Jun 3, 2015 | 07:50 AM
roll8221's Avatar
Did a leak test at the dyno, tuner wasnt quite sure why the numbers were so.low either, thats why i figured id throw it up here and get some suggestions. Not sure on the duty cycle. As for.how the car drives, ive never owned anything that had more that a couple hundred hp, so its still fast to.me but just not the numbers i was expecting...
Old Jun 3, 2015 | 08:15 AM
Dark_Teg's Avatar
What made the tuner stop making power at 350? What was the limiting factor that made him say that's all its gonna do? What kind of dyno? If it was a mainline dyno then that's your issue. They are heartbreakers if you want numbers to brag about but great for tuning.
Old Jun 3, 2015 | 08:24 AM
Full_Tilt's Avatar
No dyno? No datalog?
Old Jun 3, 2015 | 08:29 AM
diatibe24's Avatar
Well if you go by this explanation, https://www.hondata.com/techduty.html and the fact that you are running 725cc injectors and your tuner is running them in the neighborhood of 80% duty than 350whp doesn't sound to far off.
Old Jun 3, 2015 | 08:48 AM
turbohatch96y7's Avatar
Whats your map timing at?
Is your mechanical timing spot on?
Old Jun 3, 2015 | 09:29 AM
Death_to_Thieves's Avatar
Old Jun 3, 2015 | 10:28 AM
Turbo-LS's Avatar
From that vague explication you'll get a variety of answers. Could be the tune, could have leak down, could have a major boost leak of exhaust leak. Could have a restriction. Start with leak down test on a hot engine. Then start looking for boost leaks if engine is healthy
Old Jun 3, 2015 | 11:21 AM
roll8221's Avatar
Thanks, def a few things to look into.... ill try to post back if i find something... thanks again for all the input...
Old Jun 3, 2015 | 11:44 AM
DAmnquickDA's Avatar
22 psi from a 6262 with 725 cc injectors??? Something doesn't add up. Either it wasn't 22lbs or they aren't 725 cc. That's a big *** turbo pushing a lot of boost. Shooting for anything more than 350 with 725s would be stupid IMO.
Old Jun 3, 2015 | 11:51 AM
92HatchHybrid's Avatar
I could see pump gas being an issue as far as to why not push it farther. I would discuss with RealStreet though.
Old Jun 3, 2015 | 12:53 PM
TheShodan's Avatar
Moderator
We've done 350whp on 650cc older style Rochester Lucas injectors 10 years ago with plenty of duty cycle to spare.
How soon we forget over the years
Old Jun 3, 2015 | 02:13 PM
Casey's Avatar
what exhaust manifold? dp size? exhaust size? any cat converter?
Old Jun 3, 2015 | 02:17 PM
TravisBiggie's Avatar
major red flags.... you should be making over 500whp with 22 psi from a 6262..... first thing Id guess, is overboosting.. because we all know 22 psi on a 6262 with 750ccs... no bueno....
theres no way your motor is truly taking in 22lbs. you must have a major boost leak. I also advise to get retuned once you find the leak.
Old Jun 3, 2015 | 02:18 PM
also, your intercooler is a bit small.
Old Jun 3, 2015 | 03:37 PM
KevinEF7's Avatar
24 X 12 X 3 intercooler is NOT a small intercooler
Old Jun 3, 2015 | 03:40 PM
Charlie Moua's Avatar
boost leak and timing being off...
i remember when i made 240whp on turbo gsr @ 10psi...... wideband reading was of and timing was off... fixed it and did 300whp the very next pull. lol
Old Jun 3, 2015 | 04:24 PM
NotARaCist's Avatar
I never narc'd on nobody!
Not at all. Just to put it in perspective, if you're like me and couldn't visualize it...
That's 24x12x3.5, according to the owner who posted it here.
