Everyone HELP
Old Nov 5, 2002 | 04:05 PM
oldirt3277's Avatar
New User
Default Everyone HELP
Hey if you are willing to help please email me with your thoughts. I have posted numerous times about an irratic idle and all I have gotten was smart *** remarks I thought we were all here to help each other.Well here's the prob- I have a 94 ex coupe d16z6 with cold air ,a hollowed out cat,basically a straight exhaust witha tsudo pipe,chikara header and all of a sudden after my car half *** warms up it surges at idle from 1000-3000 every so often but happens less when the lights are on then my thought when the coolant fan comes on it idles steady around 1200 so what could be the problem the dealer tried to tell me that it was the IAC valve I replaced that along with the map sensor off another d16 I am building but the problem persist.The only thing is when I disconnect the throttle position sensor when running it takes the idle to 3500 and stays there so could my prob be the tps? hit me back if ya can help any thoughts appreciated. Thanks mike
Old Nov 5, 2002 | 04:11 PM
Flamenco-T's Avatar
Default Re: Everyone HELP (oldirt3277)
are you turbocharged ? hehe JK
fromn what you're describing, it sounds like a TPS problem....do this..when the car warms up and fan comes on at least twice...
held your foot at the gas pedal at 3000 RPM, and watch the RPM needle...
then post back
stan
Old Nov 5, 2002 | 04:19 PM
oldirt3277's Avatar
New User
Default Re: Everyone HELP (Flamenco-T)
no the car jumps to 3000 and stays there after I disconnect the tps.......then I have to turn off the car plug the tps back in and it idles irratic again ...........also after driving for a while sometimes the check engine light comes on but never stays on also tried to pull the codes but nothing comes up.......could ya pass this around the board
B18C-Hatch's Avatar
New User
I had an irratic idle for a while, it is similar to what you described and it turned out to be my AC compressor. i took it off and then the idle was good. Not sure if it the same prob. but you might want to look.
Old Nov 5, 2002 | 04:22 PM
oldirt3277's Avatar
New User
Default Re: Everyone HELP (B18C-Hatch)
but if it was the ac comp then it should stop with the ac on right? mine is on and of with the coolant fan
Old Nov 5, 2002 | 04:36 PM
neiloneil03's Avatar
if you suspect the tps check your voltage at the sensor
make sure it is not over .5 volts with the ignition on but not running
that or if the d is like the 92 up b t/b there is a nifty thing under the t/b that acts like a chock (it is what the coolant lines go into) sometimes that will, basiclly come unscrewed in side and cause the same simptoms
Old Nov 5, 2002 | 04:39 PM
oldirt3277's Avatar
New User
Default Re: Everyone HELP (neiloneil03)
everything is in place
Old Nov 5, 2002 | 05:31 PM
Flamenco-T's Avatar
a lot fo erratic idles also cuase by bad ground on the ignitor...
try to check and see the ground for ignitor, not sure about D series, but most B series ignitor ground is located on top of the thermostat's housing
hth
Old Nov 5, 2002 | 05:37 PM
oldirt3277's Avatar
New User
where could i find this?
Old Nov 5, 2002 | 06:09 PM
98civicEX's Avatar
sometimes when you play w/ the TPS, it needs to be reset...do this by tapping it. i'm not BSing you. You've tried everything else, it could be it jsut needs to be reset.
Old Nov 5, 2002 | 08:26 PM
oldirt3277's Avatar
New User
Default Re: Everyone HELP (98civicEX)
where should I tap
Old Nov 5, 2002 | 08:42 PM
minivan81's Avatar
Taken off your throttle body lately? Could be a wrong gasket causing air to leak in.. sounds like a vaccum problem to me
Old Nov 6, 2002 | 12:23 AM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Everyone HELP (minivan81)
hmm my buddy had that exact same problem with his 90 integra. it was a fast idle valve. I'd check the gaskets around the TB and that valve. he replaced his idle valve and everything was fine.
Old Nov 6, 2002 | 12:35 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Everyone HELP (PreIudeSI)
When you took off you IACV, did you shake it? When you shake it, it will rattle when it it bad. Its very possible that you installed a bad one also.
art
Old Nov 6, 2002 | 12:39 AM
PrecisionH23a's Avatar
Default Re: Everyone HELP (Arturbo)
what was the LAST thing you did to the engine before it started ******* up?
oldirt3277
Acura TL, RL & ZDX
Nov 6, 2002 05:56 PM
oldirt3277
Nov 6, 2002 12:09 PM
oldirt3277
Nov 6, 2002 12:02 PM
oldirt3277
Nov 6, 2002 01:36 AM
