Erratic car idle
Old Apr 22, 2003 | 07:19 AM
1sloaccord's Avatar
Default Erratic car idle
Hey guys I just wanted some insight from you guts about my car. I have a 99 accord V6 cpe. My car idles from 1500-2000 rpm, and i can feel the car gear hunt. When i come to a stop with the car in gear its revvin at 1100, put it in neutrel it jump from 1500-2000 repeatedly. Tried to reset the ecu, still does the same thing, any ideas thanks.
Old Apr 22, 2003 | 07:50 AM
88_SC_CRX_Si's Avatar
New User
Default Re: Erratic car idle (1sloaccord)
Never been around a V6, but this is some of the causes for a 4 cylinder idle to act-up...
Check your coolant level, trapped air will cause the ECT sensor to send bogus siganls to the ECU.
Check for fitmit of vacuum hoses, or a vacuum leak of some kind in the system.
Try re-setting the idle, it may have fallen out of spec.
Just some thoughts...
Old Apr 22, 2003 | 08:05 AM
Flamenco-T's Avatar
Default Re: Erratic car idle (88_SC_CRX_Si)
check the harness plug to the TPS sensor, it may be loose. Also check the ground on your ignitor, if it sounds like cutting/missing out..
stan
Old Apr 22, 2003 | 08:18 AM
1sloaccord's Avatar
Default Re: Erratic car idle (Flamenco-T)
Checked the vacume lines and the harness are all tight, anythin else?
rico892002
Mar 23, 2008 11:49 AM
allmotorsi04
May 11, 2004 04:49 PM
CRXhf90
Oct 1, 2002 01:58 PM
donkeypunch
Jul 18, 2002 10:43 AM
