Engine Tuning: eManage or eManage Ultimate
Old Jan 26, 2006 | 11:11 PM
jeffk182's Avatar
Default Engine Tuning: eManage or eManage Ultimate
Im planning on getting an eManage, but i dont know what the real difference is between the eManage and the eManage ultimate. Can someone tell me the difference between these two? Im gonna be boosting very soon, but I find that Hondata is way to expensive for my budget. Any insight would be great. Thanks guys.
-Jeff
Old Jan 27, 2006 | 05:57 AM
PM-Performance's Avatar
Default Re: Engine Tuning: eManage or eManage Ultimate (jeffk182)
Emanage wont be any cheaper once you get all the options you need.
the EMU has more fuel and timing control without needing to alter map signal and clamping the signal making timing changes, controls rev limiter, has 2 step, map tracing and auto tune and some other crap. I have the EMU on my Supra
Old Jan 27, 2006 | 08:59 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: Engine Tuning: eManage or eManage Ultimate (PM-Performance)
Neither.
For the price of an OBD-I conversion harness and a converted P06, you could run Uberdata or Crome.
If you're already OBD-I, it's a no-brainer.
Old Jan 27, 2006 | 11:40 AM
sp00led's Avatar
Default Re: Engine Tuning: eManage or eManage Ultimate (boostincoupe)
I agree....
Just go with crome/neptune/hondata/uberdata or something...
there are just to many options that are cheaper/easier than going with emanage.
This is all assuming you have access to a tuner that can tune these. If your guy only works with emanage or something then i guess that decision is kinda made for you.
Old Jan 27, 2006 | 11:55 AM
diet rite's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">Neither.
If you're already OBD-I, it's a no-brainer. </TD></TR></TABLE>
x's 59699797700033033322 been there done that Emanage will give you a bunch of headaches that can be easily avoided plus OBDI gets you laid!
Old Jan 27, 2006 | 12:15 PM
95turbodteg's Avatar
how much does uberdata or crome cost though? i never really see too many people running them and i always figured it was due to cost issues.
u can only have two pieces to the triangle... 1. fast, 2. cheap, 3. reliable
Old Jan 27, 2006 | 02:56 PM
19t EX coupe's Avatar
Default Re: (95turbodteg)
Uberdata is free, you just have to pay to have your ECU modified, but the actual program is free
Old Jan 27, 2006 | 03:04 PM
jeffk182's Avatar
I have a 00 Si so I have OBDIIb and I honestly dont have money to do a OBDI conversion. But bluntely, is the eManage a cheap alternative for Hondata, etc.?
Old Jan 27, 2006 | 04:41 PM
sp00led's Avatar
Default Re: (jeffk182)
Hondata isn't as expensive as you think it is. Start looking around for a s200b unit and you might be surprised. emanage definitely isn't just a cheap version of hondata... the cheap version of Hondata is Uberdata because its Uber free...
Old Jan 27, 2006 | 04:45 PM
TheShodan's Avatar
Moderator
Default Re: (sp00led)
The E-manage is fine. The ultimate has a few different features. It's not a "better" situation, it really about what you need.
Old Jan 27, 2006 | 07:24 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeffk182 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 00 Si so I have OBDIIb and I honestly dont have money to do a OBDI conversion. But bluntely, is the eManage a cheap alternative for Hondata, etc.?</TD></TR></TABLE>
Dude, OBD2B to OBD1 conversion harness is like 75 bucks. Add a chipped P28 for $140 and there's your engine management.
Old Feb 1, 2006 | 09:49 AM
Default Re: (EK k kay)
again Emanage is not cheaper then Hondata.
My Emanage Ultimate was close to $800 with everything.
So dont plan on it being the cheap route.
Go Hondata or Neptune or chrome or something.
Old Feb 1, 2006 | 10:23 AM
kranked91dx's Avatar
Default Re: (PM-Performance)
unless your need are high end power ( drag racing or road racing ) with full feature stand alone management... you don't need an E-manage.
it would be dumb to go an other route than Neptune, Chrome, Uberdata... Neptune got all the great feature, is cheap as expletive, and plenty of tunner on hand.
as stated before... a P28 can be had for around 150 $ and a obd2B harness to 0bd1 is like 80$...
it's really a no brainer choice unless you absolutly need like a nitrous control... etc etc etc... I even think Neptune can have those...
ne way!
hope this help
Kranked
Old Feb 1, 2006 | 12:02 PM
UK_prelude VTEC's Avatar
Default Re: (kranked91dx)
I have an emanage question - does the basic emanage unit control ignition maps as well, or is it just fuel? If I went with basic emanage, would I need to find a separate sloution for timing retard (planning to boost 5-6psi) or is it better to just go with ultimate in the first place?
I do not have a Hondata / Uberdata / Crome / Neptune option as my car (95 BB4) is an Auto 'box - that leaves me with VAFC hack, FMU/ML or emanage. And I'm not doing a manual swap (99% of cars here are manual, so auto is the stand-out option, plus don't tell me 'real men drive stick' - my dick's big enough already, so I don't need 'stick'!)
Old Feb 1, 2006 | 01:57 PM
Default Re: (UK_prelude VTEC)
I believe the plain old emanage with no options can only trim fuel.
You need other harnesses to add fuel and do timing maps and the EMU has even more wires for all the other options
Old Feb 1, 2006 | 03:17 PM
mike93boost's Avatar
i love emanage.. its so ****** easy to use. all the people that say you need to buy all this extra ****.. expletive i got all my harnesses for $30.. includes fuel, ignition, and a/f. it does everything! datalogs everything! even a/f ratio and boost. it does not alter the map signal to add fuel. it does it just like any other form of engine management does it. what do you think the injector harness is for?
it is JUST AS GOOD as anything else out there. the only difference between it and the chips is that instead of it all being the real true values, you just add or take away from the stock values of the ecu. which i think makes it super easy to tune.
Old Feb 1, 2006 | 04:59 PM
Weq's Avatar
Weq
mike is right, if ur paying full price for a emanage, ur dumb.
2nd hand they go on ebay for like 100-150. dont pay more. The harnesses can be EASILY rigged up with a parts from electrical suppliers (even a rx7 series 4 headunit harness will plug'n'play if u wanna be lazy), a GM 3bar can be rigged up for boost above stock map, all for very little money. u can get a clone cable for $50 which gives u 16x16 fuel and timing maps, add a wideband and u can autotune, log everything under the sun etc etc etc
just to add - there is other 3rd party software out there for free, which allows digital dash, dyno runs (like a gtech) and the emange will always hold value better because it can be used on any 4-6cyl engine.
Founder
K Series
Jan 30, 2014 11:20 AM
djnikko
Engine Management and Tuning
Nov 28, 2009 04:34 PM
8_6 luder
Dec 7, 2006 05:26 AM
BioXide02
Jun 30, 2005 01:53 PM
PrecisionH23a
Sep 2, 2002 10:42 AM
