Engine sputtering bad and hesitating under load
Old May 7, 2005 | 10:37 AM
Dr Pooface's Avatar
Default Engine sputtering bad and hesitating under load
Pulled the wire off plug #4 and found the plug chase full of coolant. Head gasket I presume?? I'm pullin the head tomorrow to check it out, hopefully nothing is bent/cracked.
What should I do if I get coolant in the cylanders when I pull the head? Wipe it out and WD-40?
Old May 7, 2005 | 10:56 AM
GDM Z28's Avatar
Default Re: Engine sputtering bad and hesitating under load (Dr Pooface)
y dont u do a leak down test first? also yeah just use a paper towel to suck it up
Old May 8, 2005 | 07:14 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">Pulled the wire off plug #4 and found the plug chase full of coolant. Head gasket I presume?? I'm pullin the head tomorrow to check it out, hopefully nothing is bent/cracked</TD></TR></TABLE>
Shitty. Hopefully not a cracked cylinder or anything like that.
What's a spark plug chase? The white insulator around the center electrode? Or are you talking about something else?
Old May 9, 2005 | 05:11 AM
Dr Pooface's Avatar
Default Re: Engine sputtering bad and hesitating under load (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote"> Shitty. Hopefully not a cracked cylinder or anything like that.
What's a spark plug chase? The white insulator around the center electrode? Or are you talking about something else?</TD></TR></TABLE>
Thats the only thing I could think to name the "cylander you slide the spark plug down when you goi to install it"
The teardown begins wednesday. I get to do it in my appartments underground parking garage
Old May 9, 2005 | 06:55 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">Thats the only thing I could think to name the "cylander you slide the spark plug down when you goi to install it"</TD></TR></TABLE>
So, the coolant was actually OUTSIDE the cylinder, and not inside it? Any chance you're looking at rain water or spilled coolant? Where did the coolant come from?
At least you're not outside working on this in the sun and rain. Do you have any power in your garage at least?
-Chris
Old May 14, 2005 | 06:42 AM
Chris F's Avatar
Any luck?
Old May 14, 2005 | 08:57 AM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Any luck?</TD></TR></TABLE>
I've meditated on it for a few, and now I remember that about 2 weeks before I had the problem I washed the engine bay, so maybe the "coolant" that I saw in there was just water from washing, and the missing and hesitation was from the water shorting the plug out. I wonder why it took so long to go bad.....?
Now I don't know what to do. I'd hate to pull the head for nothing. Maybe I"ll just clean it up, change the plugs, and see if she runs. Whats the worst thing that could happen? *snikker*
Old May 14, 2005 | 10:03 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">Now I don't know what to do. I'd hate to pull the head for nothing. Maybe I"ll just clean it up, change the plugs, and see if she runs. Whats the worst thing that could happen? *snikker*</TD></TR></TABLE>
The worst thing? hahahaha...
Yeah, I don't see how coolant could get in there. I'm gonna bet that was your issue.
Anyhow, light 'em up!
kkarl
Nov 18, 2012 08:35 PM
Beto760
10
Jul 22, 2011 04:50 PM
95_Civic_4dr
13
May 1, 2010 07:19 AM
jdm_vtec
Mar 2, 2008 04:27 PM
fbp cd5
Sep 26, 2006 05:39 AM
