Engine Rebuilt...Wont Start....
Old Mar 27, 2003 | 10:54 PM
  #51
shadowdawn's Avatar
Default Re: Engine Rebuilt...Wont Start.... (BVM)
Why wouldnt polartiy matter..isnt an injector like a solinoid and if switch it then it would be closed on start up instead of open..... Im just want to know alittle more b4 I go hack my harness up some more.
It doesn't matter, because I wired up my RC's like in random orders as far as both the wires to each injector, and all work just fine.
As far as grounds go, I once drove my car around all day with the engine ground wire off (whoops) but I suppose if ALL the grounds of the engine are not connected that must effect something right?
At this point check everything everyone is telling you (that you haven't already) as crazy as it might be.
Old Mar 28, 2003 | 08:05 PM
  #52
JDM EG2's Avatar
Default Re: Engine Rebuilt...Wont Start.... (shadowdawn)
The most important ground is the tranny ground. Make sure it is connected to the front subframe. Also make sure your ground is connected by the thermostat.
Old Mar 31, 2003 | 06:24 AM
  #53
T3T495GSR's Avatar
Default Re: Engine Rebuilt...Wont Start.... (TurboB16Coupe)
sounds like you almost got it figured out brandon
good luck , i hope to see that thing running soon
Old Apr 4, 2003 | 02:20 PM
  #54
HIPEmotorsports's Avatar
Any luck yet ?
Old Apr 4, 2003 | 03:52 PM
  #55
Evil EG's Avatar
Default Re: Engine Rebuilt...Wont Start.... (HIPEmotorsports)
Any luck yet ?
Not yet havent had time to work on it. Tomarrow im gunna tool around somemore.
Old May 11, 2003 | 05:53 PM
  #56
Evil EG's Avatar
Well, finally the car is running. I did a valve adjustment and put more water in the battery(it was boiling, left on the charger to long ) gave it some gas and it started right up. Now my problem is it wont rev past 1700 rpms. Im running the hack and ive played with the settings but it still does it right now im cutting 38 all across the board my fuel press is around 50. I thought it might be a vac leak but the vac gauge holds steady right around 20. Any ideas? Also when it gets to 1700 you can floor it and it wont go anywhere like its not getting fuel either. Also the V-Afc is hooked up right, triple checked it and all the volt readings were correct.
-thanks
Old May 11, 2003 | 06:35 PM
  #57
Broken Gearbox's Avatar
yay..finally...hehe...did you check for any codes??
Old May 11, 2003 | 06:51 PM
  #58
JDM EG2's Avatar
lower your fpr to 40psi....sounds like your to rich
if you ever tried putting a 12:1 fmu on 310cc injector's you'll know what I mean
the coupe in the sig is @ 40psi with -38 @ every rpm except 1k @ -34 to idle it
on the dyno a/f was 11.7 and pretty flat across the board....still a little to rich....could have still leaned it out some
Old May 12, 2003 | 07:56 AM
  #59
T3T495GSR's Avatar
try setting narrow at -43k for idle and then go to -41 for 2k to 3k then 4k -40 then -38 for 5k then -37 for 6k and so on and do the same for wide throttle too . also it wont want to move unless you mess with the throttle settings, people say to do 98% and 99% but the best one is 72% and 73%. if you are too rich it wont want to rev that high or go past 1700 rpm. now that its running, get that thing over here and show it to me
Old May 12, 2003 | 09:15 AM
  #60
Johnyquest's Avatar
just a quick suggestion but it seems like you have a shitload of problems... and the cause may be very simple... under the etc menu i beleive is a SENSOR TYPE setting... do you have it set up to pressure, and IN and OUT both set to #6? It's an easy thing to miss (I missed the #6 part) and it fucked everything up. Sounds like your in the same boat?!
Old May 12, 2003 | 09:43 AM
  #61
T3T495GSR's Avatar
Default Re: (Johnyquest)
he might, hes had the thing running before though so i doubt it
Old Feb 12, 2009 | 10:19 PM
  #62
mario_pic's Avatar
-thanks
did u replace piston rings if so did u position them in the right order as shown in the honda bible if u placed them with the gaps back to back or all along eachother it will cause problems do keep priming the car and check ur oil if there is gas in the oil u dident positon ur piston rings the right way i found that out the hard way
Old Feb 12, 2009 | 11:50 PM
  #63
'94civic b16's Avatar
I'm sure he would have appreciated this advice 6 YEARS AGO!
Old Apr 29, 2009 | 03:02 AM
  #64
h2b_sedan's Avatar
LMAO check dates man
Old Apr 29, 2009 | 09:03 PM
  #65
civic_driver's Avatar
Anyway, for those reading this thread, the ground wires are important because without them there's no path for the current to return to the battery/alternator and without that the car won't start/run.
EJ1_CRIS_909
Jul 17, 2011 08:59 AM
the.hamburglar
Jul 1, 2005 08:01 AM
Boosted Chemist
71
Oct 11, 2004 06:40 PM
SOFLSOL
Jul 30, 2003 09:42 PM
civbeater90
Nov 26, 2002 03:05 PM
