Engine overheating...
Old Dec 23, 2001 | 06:03 PM
yoshe95si's Avatar
Default Engine overheating...
I never had any problems with my car overheating before. But now it's startin to do it alot especially if I mash on the gas a little. I have a stock radiator. Does anybody know the cause of this? Or should I get a new radiator cuz my stock one can't take the turbo anymore???
Old Dec 24, 2001 | 12:17 AM
Etylorcen's Avatar
Default Re: Engine overheating... (yoshe95si)
Are their any cracks in your radiator? Are you coolant levels low? Are both your fans working? The stock radiator should be able to handle daily driving.
Old Dec 24, 2001 | 02:24 AM
immortal's Avatar
Banned
h
e
a
d
g
a
s
k
e
t
Old Dec 24, 2001 | 02:59 AM
1fstevo's Avatar
New User
Default Re: Engine overheating... (immortal)
LOL, that was cute.
Old Dec 24, 2001 | 03:26 AM
yoshe95si's Avatar
Default Re: Engine overheating... (Etylorcen)
I don't think there's any crack in the radiator. I just had my coolant flushed and changed and I bought one of those radiator caps that are supposed to help lower the boiling point. But I never checked the fan. Come to think of it...I don't think it's workin. I'll check it tomorrow.
Old Dec 24, 2001 | 03:42 AM
immortal's Avatar
Banned
dude guarantee you its your head gasket
Old Dec 24, 2001 | 04:25 AM
yoshe95si's Avatar
Well if the fan isn't it then I guess it'll be the head gasket. I'll check later on today when I get off work. Thanks.
Old Dec 24, 2001 | 05:08 AM
rtype11's Avatar
No.............I, think it is the Head Gasket.
Old Dec 24, 2001 | 07:16 AM
SiR Kid's Avatar
New User
Default Re: Engine overheating... (rtype11)
My roommate's been spraying his car for some time now...
Here's what his does.. it'll warm up pretty badly, and sit just below the red line at hot....
When he gets on it, it'll come down IMMEDIATELY. Very quickly. Thne it will sit about half for a few minutes and slowly creep up to jsut bleow the red at Hot.
We've replaced the water pump, rad cap, and checked and found no leaks. Water stays full.
Any ideas? COmpression leaking into the water when not makeing high cylinder pressure? Headgasket for this reason... Possible?
Old Dec 24, 2001 | 07:29 AM
boost killz's Avatar
New User
Default Re: Engine overheating... (SiR Kid)
Sir KID.. Tried the thermostat?? Could be going faulty and not allowing coolant to pass through the engine when needed.. Just a suggestion man.
Nick
Old Dec 24, 2001 | 09:08 AM
SiR Kid's Avatar
New User
Default Re: Engine overheating... (boost killz)
We replaced the thermostat and then removed it completely when the replacement didn't work... So, no, it's not the thermostat THanks for playing.
Old Dec 24, 2001 | 09:24 PM
paulzy's Avatar
what about this? Try bleeding the coolant system...it will lookas if overheating if you have air bubbles in your coolant system
Old Dec 24, 2001 | 11:27 PM
yoshe95si's Avatar
Default Re: Engine overheating... (Slow_ass_4dr)
Well my fan works and I opened up my radiator cover to let any bubbles out. I was told that if it was my head gasket was bad that my exhaust would let out white smoke. Well my car didn't overheat today so we'll see how it does the rest of the week.
Old Dec 25, 2001 | 09:34 AM
immortal's Avatar
Banned
your headgasket is leaking. under normal driving you might be ok but when you step on the gas hard it leaks and you overheat. when you let go it goes back to normal. i had the SAME exact problem as you until my head gasket completely blew and white smoke went everywhere.
Old Dec 25, 2001 | 05:22 PM
.nate's Avatar
Yeah Id say head gasket... my honda did it, and while Im waiting for the damn swap for it, my beater mustang just did it today.... jeez tommorrow Im ripping the biotch apart and fixing it
Pancho2193
13
Dec 24, 2010 03:36 PM
H22Abeast
Oct 26, 2009 06:54 PM
PoMoNa_909_eM2
Honda Civic (2001 - 2005)
84
May 8, 2007 04:13 AM
IA95civicDX
Sep 10, 2005 10:21 PM
Fatty_1775
Jun 28, 2003 10:32 PM
