Engine oil light!??
Old May 18, 2010 | 02:49 PM
castle magic's Avatar
Default Engine oil light!??
Posting for a friend:
"What are the possibilities of the Oil Light coming on, what i did was change the oil pan, oil+filter, the oil pressure fitting use to be a T fitting but i charger was taken off, now i'm using a straight fitting, but it's a little longer than the OEM one."
any help would be appreciated.
Old May 18, 2010 | 03:15 PM
90sedan's Avatar
Default Re: Engine oil light!??
Is the oil light on constantly?
If there is oil in the engine, i would start by checking to make sure the oil pressure sender unit is fully plugged in.
Old May 18, 2010 | 03:34 PM
yeah it's constantly on. thanks for the input.
Old May 18, 2010 | 03:38 PM
He also said when he hits the gas to accelerate it makes a whistling sound.
Old May 18, 2010 | 08:27 PM
kw8z3boi's Avatar
bump for help
Old May 18, 2010 | 08:29 PM
enam's Avatar
Default crank pulley problem
hello there!!! need some help...i bought an accord 2002 se with 115k...its running good and vry smooth, the scrap is the crank pulley i.e the harmonic balancer...i changed it and tightened it properly though its wobbling ....the wobble is not causing the the belts displacement but my question is why its wobbling..car runs great and no sounds or knocking or under drive...at slightly higher rpm there is no wobbling at all.showed it 2 mechanics...all of them telling that its no harm and can drive it....they told me if my crank was busted then the car woulnt have run like this so its ok to drive like this....guys plz need ur expertise ...is this true or i need to take some steps to solve this issue...HELP!!!!!!
Old May 18, 2010 | 09:06 PM
bump for help
Old May 18, 2010 | 09:14 PM
90sedan's Avatar
He only changed the oil pan correct? He didn't remove the oil pick up?
Did he use any type of thread sealer when installing the new fitting? I would recommend checking to see if the passage is blocked.
If the oil pressure switch is correctly installed, and is functionally properly, then the cause of the light is due to the lack of oil flow to the switch.
Old May 18, 2010 | 09:47 PM
can you please elaborate?
Old May 18, 2010 | 10:08 PM
90sedan's Avatar
On which part?
If the oil pick up was removed, was a new one installed? Is the gasket in place? If the oil pick up was removed/replaced and the gasket wasn't installed, it would lead to poor oil circulation. That could explain the oil pressure light being on. If only the oil pan was replaced and not the pick up, then this isn't an issue.
When installing the new "straight" fitting did he seal any of the threads? Check to see if any of the sealant is blocking the oil passage.
If the oil pressure switch is properly plugged in, and it is a known good oil pressure switch (when they fail, the oil pressure light will constantly be on) then the only reason why the oil pressure light would be on constantly would be low oil flow to the switch. That's assuming there is enough oil in the engine to begin with.
Honestly, without seeing the car it difficult. Your friend needs to double check his work.
Old May 18, 2010 | 10:18 PM
thanks for your help. yeah i know it makes a diagnosis harder since i don't even know what was really going on with the car. i'm just posting this up since he doesn't have access to a computer at the moment. thanks for the helpful details.
Old May 18, 2010 | 11:07 PM
nihad's Avatar
Some people dont need to work on car.s...
Old May 18, 2010 | 11:11 PM
^i agree, but we all need to start from somewhere.
Jmtfrtc
Oct 29, 2018 12:46 PM
IBriaIN
Feb 27, 2011 08:28 PM
kmcgillic91
Jan 23, 2011 07:47 AM
SofireGuy
Feb 16, 2009 10:08 AM
MadCityLude
Oct 11, 2006 02:36 AM
