Engine oil ?
Hello pls need help to pick a good engine oil for my B20vtec turbo car the option Y have are : Lucas oil 20-50 , Castrol 5-50, Eneos oil 0-50 or 15-40 , Redline 15-50, Shell Ultra 5-40 , Mobil 1 15-50
Witch of this oil will be the best for my car where I live there is no winter and is really hot place. My car is doing 500whp and rev to 9000 rpm
brad penn 20w50
http://t1raceparts.com/en/products/d...acing-oil.html
Depending on the use of the engine but for a street car I would use a 10w-30 after that is just a matter of brand pref. I like mobil1 and Royal purpple in my modded engines but if it's just the DD then I use mobil5000. The only time I would use above a 10w-30 is for a race only engine but even then I would only use a 15w-40.
Well think about the purpose of the oil.. To lube and cool! What is hondas recommended viscosity (10w-30 in most engines, never above), y is that the recommended viscosity?? Because of the clearances of the oil passages! There is no real gain behind using a thick a$$ oil besides a high oil pressure. It doesn't lubricate or cool any better nor does it stop oil consumption. Just because ur oil pressure is higher doesn't mean it's working better either, it just means it's harder for the oil pump to pump it. I'm more interested to hear y u guys think it's better to run such high viscosity oil..! Remember ur not driving old fords or chevy's with sloppy lose tolerances.
EG-SIXV-TEC
Jun 12, 2010 10:47 PM
