Engine Management Questions????
Old Jan 4, 2004 | 08:00 PM
streetlvlhatch's Avatar
Default Engine Management Questions????
I currently have an emanage and am not sure if i should switch to hondata. My question is that i want to be able to switch boost levels on the fly. I want to know if any systems out their allow for it. I want to be able to cruise at like 7psi and then crank it to 15 when i need to race. Do any of the systems out there sense the increase in boost and change to different fuel charts. I want to tune for each psi and have the system recongnize it. Is this possible? If not, i am assuming my car would run shitty at 7psi with a 15psi tune?
Old Jan 4, 2004 | 08:20 PM
p0gi's Avatar
Default Re: Engine Management Questions???? (streetlvlhatch)
you can set your emanage to have fuel maps up to 2 bar with the optional 3 bar map sensor. Just tune it at whatever presets you want and you wont need to change your fuel map coz it will already be there
Old Jan 4, 2004 | 08:26 PM
Default Re: Engine Management Questions???? (p0gi)
so you are saying that the emanage can recognize the increase in boost and change to the other tune?
Old Jan 4, 2004 | 08:27 PM
i got the extra boost sensor thing from greddy, I guess it allows you to not have the 3 bar sensor.
Old Jan 5, 2004 | 07:06 AM
p0gi's Avatar
you just program the tune up to or beyond whatever level you want to run, you wont need to switch maps, coz your map will have settings up to that boost level.
Old Jan 5, 2004 | 07:19 AM
toxicshit's Avatar
just tune to the boost-level you want max and use a electronic WG and a boostcontroller
Old Jan 5, 2004 | 09:46 AM
Default Re: (toxicshit)
so if i tune for 15psi, will i be running rich when i am at 7psi? will the car still perform good?
Old Jan 5, 2004 | 11:54 AM
Default Re: (streetlvlhatch)
HELP!!!!!
Old Jan 5, 2004 | 12:00 PM
DC2R714's Avatar
Think of Hondata like an Excel spreadsheet. Each column acts as a certain amount of pressure or vacuum. The added tables are boost tables. So if you tune up to 15psi you will have tables up to 15psi, meaning you can boost anywhere in between. If you are going to run 7psi all the time. Tune the maps for 7psi then tune 15psi. This will give you accurate maps for anything from 1psi-15psi.
Emanage works the same way, by adding boost tables.
97grnrs
Dec 8, 2007 12:46 PM
XxRoCkMaNxNEOxX
Jan 23, 2005 11:43 AM
f1 vtec
Nov 1, 2004 09:38 PM
redline201
Dec 3, 2002 04:35 PM
turboex
Sep 13, 2002 12:00 PM
