Engine/Crank balancing....should I do it?
Old Sep 27, 2002 | 11:39 PM
IntegD's Avatar
New User
Default Engine/Crank balancing....should I do it?
I am tearing down my all motor setup to make it into a turbo setup. I previously put all new bearings in and had it balanced. My question is, with me changing my bore size to 81.5mm(from 81.0) and getting a new clutch and bearings etc, should I rebalance the rotating assembly?? I am assuming the main effect of an improperly balanced rotating assembly is bearing wear, leading to premature bearing failure. Any insight on this is greatly appreciated as I will be taking the block to a machine shop sometime this up coming week.
Old Sep 28, 2002 | 08:24 AM
earl's Avatar
Default Re: Engine/Crank balancing....should I do it? (IntegD)
If balanced properly the first time, no need to rebalance
FK00GSR
Mar 14, 2011 05:08 PM
SuckMyDOHC
Jun 15, 2008 11:29 AM
D.Dappa
Jul 16, 2007 01:57 PM
nY's FiNeSt
Jul 14, 2006 07:20 PM
PrecisionH23a
Jul 30, 2002 02:28 AM
