Engine Builders please help with choosing bearings
Old Nov 15, 2008 | 01:49 PM
nonvteclude's Avatar
Default Engine Builders please help with choosing bearings
hey guys i am finishing up my engine build and im down to choosing bearing sizes. i just had my block align honed and the crank balanced and polished. while i was getting the h23 sleeved the block cracked so the mechanist used a h22a4 block, so im alittle confused on which bearings to choose. the mains were honed to 59.02mm and the mains on the crank, crank pulley side to flywheel
1) 50.01mm
2)50.01mm
3) 50.02mm
4)50.00mm
5)50.00mm.
the rods are crower with 51.00mm big end with crank again same order
1) 48.00mm
2) 48.01mm
3) 47.99mm
4)48.00mm.
if anyone could help me out that would be greatly appreciated. if i need different info i will get it.
thanks for reading
Old Nov 18, 2008 | 02:29 AM
deucedeuceEK's Avatar
you can't put an h23 crank in an a4 block.
Old Nov 18, 2008 | 03:08 AM
alterdcreations's Avatar
as long as its a 97 year a4 block it will work.. but i am confused..59mm mains?
Old Nov 18, 2008 | 08:29 AM
lsturbohatch10's Avatar
there is a 9 millimetter difference there. and their arent any 4.499mm bearings to my knowledge.
Old Nov 18, 2008 | 09:31 AM
jarvis199's Avatar
yea taht started to look confusing for a second...
rbeharry
May 15, 2009 09:28 PM
nonvteclude
Nov 23, 2008 03:27 PM
vtechachey
Mar 4, 2008 08:52 PM
Pandahatch
Feb 26, 2006 10:08 AM
cal_
Feb 6, 2005 12:32 AM
