engine builders opinions
Old Dec 30, 2006 | 11:23 PM
lsvtechatch92's Avatar
Default engine builders opinions
im about to be buildin a piston and rod set up ls vtec 10 to 1 compression eagle rods je pistons... 81.5 mm bore... i will be boosted what do you guys usually put yalls piston to wall clearance at.... and what ring placement and gap do you use.... my crank is fine ...so i should be fine with standard bearings correct... just getting different peopls opinions
Old Dec 31, 2006 | 09:33 AM
DRAGLS's Avatar
Default Re: engine builders opinions (lsvtechatch92)
The aftermarket pistons that you will be putting in has all those specs included.
Old Dec 31, 2006 | 12:42 PM
ccivic's Avatar
I believe JE calls for .0030" piston-to-wall clearance, but it really depends on how much power you plan on producing. What are your goals?
EDIT: .0030 not .030
Modified by ccivic at 2:56 PM 1/1/2007
Old Dec 31, 2006 | 01:00 PM
Default Re: engine builders opinions (ccivic)
prolly aroun 400 daily and 500 with race gas
Old Dec 31, 2006 | 03:13 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">I believe JE calls for .030 piston-to-wall clearance, but it really depends on how much power you plan on producing. What are your goals?</TD></TR></TABLE>
Do you mean .003"?
Old Dec 31, 2006 | 04:46 PM
ExospeedAMcrx's Avatar
piston to wall clearance should be with the spec sheet that came with the pistons.
LS/V-T
Jan 5, 2011 09:19 AM
RC000E
Feb 18, 2008 07:48 PM
lsvtechatch92
Jan 5, 2007 06:21 PM
codyb13
Feb 13, 2006 04:41 AM
ptsaurus
Mar 20, 2004 05:33 PM
