Engine Builder:Need help with Arias Pistons 3320202
Old Jun 27, 2006 | 05:08 AM
QuickEJ6's Avatar
Default Engine Builder:Need help with Arias Pistons 3320202
I need the wall to pistons clearance you've when you bore the block with Arias Pistons 3320202... Ive receive 3.204 pistons from Arias ... Big error from arias .... Just need the real clearance don't want to seize my Block
Thx.
Old Jun 27, 2006 | 05:21 AM
Armed Ferret's Avatar
Default Re: Engine Builder:Need help with Arias Pistons 3320202 (QuickEJ6)
what did arias say when you called them?
Old Jun 27, 2006 | 07:15 AM
earl's Avatar
You are asking a question that only you can answer. You need to measure your own block and answer your own question.
Old Jun 27, 2006 | 10:55 AM
oscarmayer's Avatar
you also need to be VERY carefull with arias pistons, I have seen several engines that have ran then and if they get jsut a hair warmer than normal the pistosn tend to swett more causing sidewall damage and then ring failure. for soem reason they seem to be easier to cause the side shirt to rub the cyclinder walls than otehr pistons. I've seen weisco branded ones work the best with the least swelling.
GT500FTW
Engine Machining & Assembly
Jun 14, 2015 10:52 AM
CARMA_626
Dec 2, 2007 03:33 PM
I_got_your_honda
Aug 17, 2006 01:04 PM
VSBB6
May 16, 2006 09:09 AM
