Engine Build
Old Jun 7, 2002 | 08:41 PM
McFly's Avatar
Default Engine Build
I am planing to build up a B16 and want to run a 100-150 shot of nos on it. What kind of pistons and rods are recomended? Do I need a girdle for the bottom end? What about the insert that goes between the water jackets to make it a closed deck? I want to build it right and get a long life out of the motor. I'm not taking any short cuts.
[Modified by UnderFire, 5:42 AM 6/8/2002]
Old Jun 9, 2002 | 07:46 AM
McFly's Avatar
Default Re: Engine Build (UnderFire)
ttt
Old Jun 9, 2002 | 07:48 AM
Jared's Avatar
Just FYI, I've run a wet 100 shot on a stock LS using race gas before. Get a set of good rods and pistons, and run it wet and I don't think you'll have a problem as long as you get your tuning right.
b18bturbo's Avatar
really any aftermarket pistons with a good set of rods will do the trick. you can also either get your block sleeved or find a decent block guard to fit your motor. 150shot direct port system is the way to go. As long as you have the fuel you should be okay.
Old Jun 9, 2002 | 07:57 AM
McFly's Avatar
Thanks. I planed on running a wet kit with either a direct port system or a gsr head with gsr intake and plate system. Which is better? Also, does anyone recomend a good brand for pistons, rods, and bearings? Thanks
Old Jun 9, 2002 | 11:17 AM
DLB1994's Avatar
100shot dp nos stock bottom end
Old Jun 9, 2002 | 11:48 AM
PrecisionH23a's Avatar
JE 9:1 pistons, crower rods, darton/GE sleeves
Old Jun 9, 2002 | 12:15 PM
Paul Walker's Avatar
Default Re: Engine Build (DLB1994)
Old Jun 9, 2002 | 12:16 PM
Etylorcen's Avatar
Default Re: Engine Build (Paul Walker)
No need for crower rods...just go with eagle and save yourself a lot of money.
Old Jun 9, 2002 | 12:56 PM
1337 Si's Avatar
Default Re: Engine Build (Etylorcen)
Darton sleeves for me!
Civic driven01
Apr 16, 2004 07:20 AM
Modifiedinteg
Nov 27, 2003 05:27 PM
blueskiesfade609
Nov 14, 2003 12:09 PM
ABLUEINTEG97
Aug 16, 2002 07:46 AM
