engine breaking up
Old Oct 26, 2005 | 08:14 PM
00000xxx's Avatar
Default engine breaking up
my friend boosted his built b18c hatch with a full race turbo kit. He had it tuned by Jeff Evans using Neptune. well during the tuning session the motor kept breaking up, Jeff didn't know why it did so. Jeff held on to the car for a few days to figure out the problem but with no luck of finding the source. Then he tried different ecu's, coil in the dizzy, spark plug wires, dizzy caps, spark plugs, re-wired the tps sensor, and a few other things that i don't know about. So now he has been driving around with a 400whp hatch and doesn't know when he will make power or break up. What we do know is the car only breaks up when the motor gets hot and is seems like its a ignition cut of some sort.
If you need more info feel free to ask, helpful comments only please.
This car makes 396whp in high boost so it would be nice to feel the power with out breaking up. Thanks in advance.
Modified by ctr610 at 6:14 PM 10/29/2005
Old Nov 2, 2005 | 04:10 PM
00000xxx's Avatar
Default Re: engine breaking up (ctr610)
anybody think it can be the wastegate not holding boost? it only breaks up at higher rpms and wont build boost, i've been telling him to try a different spring. let me know what you fellows think
Later
Old Nov 2, 2005 | 04:12 PM
komat's Avatar
what spring do you have on right now and what boost you running
Old Nov 2, 2005 | 04:23 PM
Blaze45's Avatar
Brrraaaap!
Default Re: engine breaking up (komat)
It could be a fuel delivery issue. We need details of the seutp. If Jeff Evans couldnt figure it out then you definetly have some troubleshooting to do.
Blaze
Old Nov 2, 2005 | 06:11 PM
00000xxx's Avatar
Default Re: engine breaking up (Blaze45)
Keep in mind...This is not my car so I i don't know everyday driving characteristics.. Thanks for your time
here it goes
Motor specs:
B18c1 block 9.0:1 cr .020 overbore
b16a head w/ gsr cams with ferrera valves i believe, 3 way valve job
Full Race cam gears
b16 intake manifold
GSR tranny
Fuel delivery:
Walbro 255 fuel pump (may have a dirty sock)
RC 750cc's fuel injectors
stock fuel rail and regulator
Stock and original fuel filter (could be the problem)
Full Race Stage1 (450hp) Turbo kit:
T3/T04 60 trim turbo
Full Race equal length manifold
Tial 38mm wastegate with 7lb spring
Tial 50mm BOV
Stock Dizzy/cap/ rotor/ coil
MSD wires
Spark Plugs ?
Engine management:
Neptune tuned by Jeff Evans
The results:
Low boost 320hp @ 10lbs
high boost 396hp @16lbs
The motor is now throwing code 43 Fuel system supply
The motor will run great for a few minutes in high boost then it will run like garbage after that and VTEC wont engage, and wont hold boost....
Here is his Dyno Graph http://forums.evans-tuning.com...=2664 (keep in mind it only breaks up during street runs, it pulled hard and clean on the dyno) I just reiterated what the boosted pages said
Old Nov 4, 2005 | 02:28 PM
00000xxx's Avatar
bump
Old Nov 4, 2005 | 03:47 PM
turbotime's Avatar
was the dyno losing signal? Was it ony happeneing in higher rpms?
My honda-tech jedi power sense your buddies IGNITOR is dead/dying. Replace the ignitor or the whole dizz.
i replaced the whole dizzy when having the same issues, breaking up/fuel cut type symptom > 4k rpms, randomly.
The guys at the dyno said the bearing in the dizzy can come loose or something and at high rpms it will cause the rotor to not make contact with the cap.
Not sure if it was the bearing or the ignitor, but replacing the whole dizzy fixed it, only after replacing the cap, rotor, spark, and wires didnt
hope this helps!
Old Nov 4, 2005 | 08:22 PM
00000xxx's Avatar
Default Re: (turbotime)
I'll check it out, thanks
POWERSHIFT IRAN
May 16, 2017 02:25 AM
LiLJisBooSTin89
Aug 22, 2014 07:15 AM
Martian
Feb 7, 2010 07:17 AM
Wuman
Sep 13, 2009 10:32 AM
B00STED Si
Aug 19, 2005 05:08 AM
