Which engine best to BOOST: B16A SIR II or B18B???
I really need your opinions and experiences on this so please help me out. First, im driving 94 eg(dx)-D15B7 with about 250k on both enging and body. I decided I'm gonna do a swap this coming summer and put a B-series. I want to get the engine before summer so that I can replace timing belt, water pump etc.., before summer comes. This is my project this coming summer and looking forward for next year, TURBO ... My first choice is B16A, so which one is the best to boost. Need your experiences here and opinions. Thanks guys!!!
jOhn
jOhn
Location: On a island w/ only a bridge to leave it, U.S.A
Re: (2civic3)
I've seen some guys running alot up to 30psi and im sure there has been a higher number, it depends on the mechanical components and how well you tune your car.
Random: G2 Speed has 666 posts
Re: (NAem1)
the b18b is lower compression and handles boost well, my friend is going to make 275 whp on his ls motor with stock internals. B16's really do not have much torque to them so I wo uld not recomend buying them, I have not been impressed by a stock on yet. But there are alot of people around here running bosted b16's so they must handle it decent, have not heard any horror storys just know the ls is a better boost motor
Re: (2civic3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2civic3 »</TD></TR><TR><TD CLASS="quote">can someone post a Dyno of B18B boost here?? thanks guys for the ideas!!!</TD></TR></TABLE>
I probably can but it's not on stock internals.
You definitely want to go B18B if you're going boost, the bottom end is stronger than the B16, and with good tuning you can make respectable power on stock bottom end. The only positive aspect of boosting a B16 is VTEC, otherwise the engines have low torque. If you want VTEC, just go LSVTEC
Re: (sinesterxone)
I am all about the vtec with boost. If you have to choose between the two of them I would go with a b16. But that is just my opinion. Yeah the compression on the ls is lower which means you have a bit more room for error but if you have a solid tune you can run higher compression with out blowing up..
so how much HP can you make with B18B non-vtec stock internal with boost??? good feedbacks guys, peeps here rocks!! thanks and keep coming....
Re: Which engine best to BOOST: B16A SIR II or B18B??? (2civic3)
if you really wanna go cheap get a d16y8 SOHC or any Sohc vtec and boost it
go here if you want some more info
http://turbod16.com
http://turbod16.com
not planning to go back to SOHC yet(no offence SOHC fans). just wanna feel DOHC with boost then get another civic 4 door next summer and boost that sohc....
Re: (2civic3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2civic3 »</TD></TR><TR><TD CLASS="quote">so how much HP can you make with B18B non-vtec stock internal with boost??? good feedbacks guys, peeps here rocks!! thanks and keep coming....</TD></TR></TABLE>
I'd say with a good tune you could make 250-300, but it won't last forever that way.
Re: (RaYnE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS »</TD></TR><TR><TD CLASS="quote">
You definitely want to go B18B if you're going boost, the bottom end is stronger than the B16, and with good tuning you can make respectable power on stock bottom end. The only positive aspect of boosting a B16 is VTEC, otherwise the engines have no torque. If you want VTEC, just go LSVTEC </TD></TR></TABLE>
That would probably be your best choice. I'm going to boost my B16 eventually, but my car came with it, so.... meh
Re: (Sh!ttyLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sh!ttyLS »</TD></TR><TR><TD CLASS="quote">I probably can but it's not on stock internals.
You definitely want to go B18B if you're going boost, the bottom end is stronger than the B16, and with good tuning you can make respectable power on stock bottom end. The only positive aspect of boosting a B16 is VTEC, otherwise the engines have low torque. If you want VTEC, just go LSVTEC </TD></TR></TABLE>
Yeah you couldn't be more wrong...have you ever seen the internals of either motor?..b16's are built considerably more stout than an LS...b16's have shorter, thicker rods and bigger rod bolts, and being a shorter deck motor with a shorter stroke, the sleeves are less likely to shift..the only strength "downfall" is the higher compression ratio, which means tuning has to be more precise to avoid detonation, but the pistons themselves are not physically any weaker than an LS.Either motor will take 275-300whp with a good tune, you just have to decide which powerband you like, torque or top-end.
Re: (Sh!ttyLS)
You definitely want to go B18B if you're going boost, the bottom end is stronger than the B16, </TD></TR></TABLE>
I disagree. Have you ever compared b16/b18 rods in your hands? B16's rods are hands down stronger. That and the fact that the longer stroke puts more side load on the rods.
All that aside, I would personally start off with a LS turbo over B16, haha
Re: (leed)
I sold my full jdm b16 swap, bought a full b18 swap with the cash and had lots left over, that includes my new act clutch i ordered for it
Im sticking with the b18 for lower compression and torque, nothing compares when you have torque imo.
as for vtec, i find it pretty useless when turboed, as well, if you are wanting just the sound, trust me, vtec is pretty much gone when you boost plus, all you wanna hear after is pssssh
Re: (Dunn)
That is not true about vtec.. If you look at any dyno plot with a vtec turbo motor when the car pops over into vtec the HP just jumps.. Vtec isnt just a sound..
Re: (Dunn)
On the street a build B16 will allways beat a B18b because it has less torque at the bottom end so yoou will have more traction.
And yes vtec is imo better, und can get more WHP with it because you are getting more air to your cilinders and you can also rev it higher so you can use the powerband from a big turbo.
Re: (vti2)
true enough, never really thought of it that way.
i assumed that the dyno showed that there wasnt a jump when vtec kicked in, i always heard that it was still just as constant.
