Engine Bay BLACK?!
Old Nov 20, 2003 | 06:57 PM
JDEM1's Avatar
Default Engine Bay BLACK?!
I have a boosted 2000 civic si with maxrev manifold, on the block next to the 2nd runner on the manifold there is alot of black soot building up, is the gasket messed up?, the manifold is bolted tight and I dont know, but I assume it's leaking, How do I fix this?. TIA
Old Nov 20, 2003 | 07:30 PM
Ben Huynh's Avatar
Default Re: Engine Bay BLACK?! (JDEM1)
Is your wastegate dumping over your manifold?
Old Nov 20, 2003 | 08:14 PM
VanHonda's Avatar
Default Re: Engine Bay BLACK?! (jz)
Is there plenty of clearence for the compressor on the block?
Old Nov 20, 2003 | 11:36 PM
JDEM1's Avatar
Default Re: Engine Bay BLACK?! (VanHonda)
my wastegate is dumping out my dumptube under the car, the compressor has plenty of clearance, and I can't feel any air coming out the mani when I turn it on..
Old Nov 21, 2003 | 04:45 PM
JDEM1's Avatar
bump, need some more insight on this... I drive this car 30 miles a day, it might be hurting my performance, but it seems like my engine is okay and no smoke coming out the rear...
Old Nov 22, 2003 | 06:22 PM
Bailhatch's Avatar
You can use smoke from a cigarette to see if there are any exhaust leaks. It will blow the smoke away.
I would first try a new gasket with copper spray and properly torqued nuts if you do in fact have this leak.
Old Nov 22, 2003 | 09:25 PM
JDEM1's Avatar
Default Re: Engine Bay BLACK?! (Bailhatch)
copper spray? where do I get that and what exactly does it do..
Old Nov 24, 2003 | 04:04 PM
JDEM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDEM1 &raquo;</TD></TR><TR><TD CLASS="quote">copper spray? where do I get that and what exactly does it do.. </TD></TR></TABLE>
is there anyone in so cali that can check it out?
12x
Sep 20, 2006 08:30 AM
simike
Apr 8, 2005 10:12 PM
B20LS-T
Apr 3, 2003 06:04 PM
Turbo Powa
Apr 3, 2003 08:15 AM
chri5
Oct 11, 2001 10:07 PM
