Endyn Cams?
Old Mar 20, 2011 | 07:36 PM
LS/V-T's Avatar
Icon2 Endyn Cams?
I'm pretty new to turbocharged Hondas and realize there are several turbo builds using N/A cams (pro1s,ITR,ect..) and they making a lot of power.
A local guy has a set of Endyn Bumpstix Cams for a b series up for sale at a great price. Would these cams be a good choice for a built turbo b series shooting for 500-600 whp? If not can you explain??
Old Mar 20, 2011 | 07:54 PM
LS/V-T's Avatar
Default Re: Endyn Cams?
Intake Valve Lift .481 Valve Lash Cold .006”
Intake Duration 268 Degrees @ 1mm (.040”) Valve Lift
Exhaust Valve Lift .458” Valve Lash Cold .007”
Exhaust Duration 264 Degrees @ 1mm (.040”) Valve Lift
Old Mar 20, 2011 | 08:04 PM
2k.civic.si's Avatar
stock cams are usually best except for very high boost applications. if you are really going for 600whp i would use the skunk2 pro1 cams.
Old Mar 20, 2011 | 08:40 PM
LS/V-T's Avatar
Icon3 Re: Endyn Cams?
Here's the specs on the the Bumpstix vs pro1s..
E.B. Int. 12.21mm 268*
S2P1. Int. 12.6mm 264*
E.B. Exh. 11.63mm 264*
S2P1 Exh. 11.9mm 264*
Old Mar 20, 2011 | 08:43 PM
cibao2ner's Avatar
endyn told me for turbo only use the endyn intake cam and an itr exhaust cam....
Old Mar 21, 2011 | 04:02 AM
Tony the Tiger's Avatar
Yup, same suggestions ENDYN has offered me... Soon, I will try out their cam combo when I am ready for more power.
Old Mar 21, 2011 | 08:53 AM
civic-r11's Avatar
How much for the intake cam only? I know the set costs 555.. so i am hoping it is half that..
Old Mar 21, 2011 | 12:43 PM
LS/V-T's Avatar
I am really interested in how well this setup will respond..
If anyone has more info on boosted applications using Endyn cams please share!
jason007
Dec 27, 2007 01:09 PM
exownzu
Sep 30, 2006 08:58 AM
Absentmind
Nov 8, 2005 02:19 PM
fiebru1119
Mar 6, 2002 03:40 AM
