Endyn Breather
Old Jul 30, 2005 | 11:46 PM
95boostedteg's Avatar
Default Endyn Breather
How is everyone running their endyn breather kits with their turbo? Do the majority of you guys run it with the filter on top or with the pvc valve instead? Thanks
Old Jul 31, 2005 | 05:21 AM
Rod.'s Avatar
Default Re: Endyn Breather (95boostedteg)
filter for me
Old Jul 31, 2005 | 06:36 AM
rmcdaniels's Avatar
filter, too much crankcase pressure buildup with the PCV
Old Jul 31, 2005 | 07:30 AM
mrDFWmechanic's Avatar
hopefully i'll be buying the endyn kit within the next month, by friends have got it and it works awsome
Old Jul 31, 2005 | 09:34 AM
300whpOrBust's Avatar
Default Re: (iROCKtheSOHC)
Not to thread jack but:
Where are ya'll buying your endyn kits from? And the endyn kit is the one that comes with those freeze plugs isn't it?
Old Jul 31, 2005 | 09:55 AM
Sprockets's Avatar
I use the filter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 300whpOrBust &raquo;</TD></TR><TR><TD CLASS="quote">Not to thread jack but:
Where are ya'll buying your endyn kits from? And the endyn kit is the one that comes with those freeze plugs isn't it? </TD></TR></TABLE>
It just comes with 1 freeze plug. Some people piece together the kit themselves, but an extra 3/8" NPT bung needs to be welded on the Moroso can. Or, you can buy it here:
https://honda-tech.com/zerothread?id=1137242&page=1
Old Jul 31, 2005 | 09:57 AM
tegman2's Avatar
Default Re: (USE2B16A)
whats the diameter of the neck that the filter goes on?
Old Jul 31, 2005 | 10:05 AM
SpdFrk's Avatar
Default Re: (tegman2)
Filter on.
Old Jul 31, 2005 | 11:45 AM
tegman2's Avatar
Default Re: (SpdFrk)
Im making my own and want to know what size the opening on top of the can is. Thanks
Old Jul 31, 2005 | 12:46 PM
Sprockets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegman2 &raquo;</TD></TR><TR><TD CLASS="quote">Im making my own and want to know what size the opening on top of the can is. Thanks</TD></TR></TABLE>
If you buy the Moroso can, it comes with the filter.
Old Jul 31, 2005 | 01:10 PM
Thanks everyone. I will run it with the filter.
Old Aug 1, 2005 | 05:11 AM
I noticed that running running with the filter on, it smokes a little and oil is coming out of my filter. any suggestions for fixing that problem?
Old Aug 1, 2005 | 06:50 AM
vaporboy12's Avatar
fast-turbo.com stan can get it for you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95boostedteg &raquo;</TD></TR><TR><TD CLASS="quote">I noticed that running running with the filter on, it smokes a little and oil is coming out of my filter. any suggestions for fixing that problem?</TD></TR></TABLE>
thats normal mine does the same thing its.that means its doing the job of vent the crank case
ex_ricer
Apr 12, 2007 11:44 AM
a1320addict
Jan 14, 2007 08:04 AM
Shake and Bake
12
Dec 28, 2005 08:40 PM
zentraedityper
20
Sep 28, 2005 05:16 PM
