EMS guys I need some help!
Old Aug 15, 2003 | 02:41 PM
Canuk_SiR's Avatar
Default EMS guys I need some help!
I recently upgraded to V1.0, and as I converted my V0.89 cal. file over to 1.0, I had a problem where when I turn the key to the on position, the fuel pump wouldn't prime. I thought maybe it could be the file itself, so I converted a similar map to 1.0, and still get the same thing. I tried a 1.0 base map, and the pump primed up normally, so I know that the pump didn't get fried. I'm just wondering if anyone else had any problems as they converted over to 1.0, cause this is a big pain in the ***. I can't get anything decent out of the base map, the fuel values are way off, and I already spent alot of time with my V0.89 map that I'd rather not have to start over with a new cal. file.
Also, if you've got a converted cal. file, would it be too much to ask if I could get a copy of it, just to see if my aem doesen't like converted files? Or if anyone is willing, to convert my old file with their software that has successfully converted an older file to 1.0, cause maybe my software is screwing stuff up.
Thnks in advance for any help you could offer
Old Aug 16, 2003 | 05:46 AM
Canuk_SiR's Avatar
Default Re: EMS guys I need some help! (Canuk_SiR)
bump
can anyone help me out???
Old Aug 16, 2003 | 08:10 AM
Mase's Avatar
if you are still having trouble, use a map that works, then use your fuel and ignition curves from you old map and go from there.
Old Aug 16, 2003 | 10:09 AM
racerxadam's Avatar
Default Re: EMS guys I need some help! (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">if you are still having trouble, use a map that works, then use your fuel and ignition curves from you old map and go from there. </TD></TR></TABLE>
this is also what I would suggest.
donperry
Engine Management and Tuning
14
Aug 19, 2015 05:45 PM
justnprsh07
Mar 11, 2011 02:10 PM
ExVtec
Honda S2000
Apr 25, 2009 09:24 AM
Acura_I-RS
Oct 24, 2005 05:04 AM
Universal Magnetic
May 20, 2003 05:48 PM
