electronic or manual dual stage boost controller...???
Old Apr 12, 2007 | 01:23 PM
ken00si's Avatar
Default electronic or manual dual stage boost controller...???
I will be taking my car in to get a Neptune tune in a couple weeks and called the tuner for some advice regarding a boost controller. I already purchased a Greddy Profec B - Spec 2 boost controller and was planning to use this, however they said that it is difficult to use, and instead I should get a TurboXS dual stage manual boost controller because it is much more simple. I am a Noob and don't know all the logistics behind the Greddy, but isn't it supposed to be better because it is electronic and you can fine tune it???
What do you guys think??? Any suggestions are appreciated. Thanks in advance!!!
Old Apr 12, 2007 | 02:24 PM
chubz0r's Avatar
Default Re: electronic or manual dual stage boost controller...??? (ken00si)
I have a manual dual stage and have zero complaints about it. so simple to use and setup. i have no experience with the greddy, but i suggest you sell it and pocket the extra cash you save after getting a turboxs dual stage. good luck
Old Apr 12, 2007 | 04:24 PM
HiProfile's Avatar
You can fine tune it, but it will be a headache to attempt it if you're new to them. Its more than setting the PSI you want.
A TurboXS dual-stage mbs is very simple, even if its the one with fine adjustment. Its 2 or 3 screws to adjust boost levels, one wire goes to ground, then one wire to your powered switch.
Old Apr 12, 2007 | 04:34 PM
tony413's Avatar
budget= DUAL or TRIPLE stage mbc
no budget = ebc
Old Apr 13, 2007 | 07:19 AM
ken00si's Avatar
Default Re: (tony413)
Thanks for the replies!
I don't really have a budget and am planning to pay top $ for tuning, so I'm down with the ebc in order to fine tune it and see better results.
Question...when I switch the boost controller from street to race, how does the system compensate for the extra fuel that is needed for higher boost???
Old Apr 13, 2007 | 08:20 AM
tony413's Avatar
Default Re: (ken00si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ken00si &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies!
Question...when I switch the boost controller from street to race, how does the system compensate for the extra fuel that is needed for higher boost???</TD></TR></TABLE>
thats what we have sensors for when your car gets tuned you'll learn how its all done assume your tuner is a nice guy
spoolin_teg
Jun 26, 2007 08:09 PM
s2kkid
Nov 6, 2005 11:02 AM
Turbocivic94
Apr 18, 2005 07:59 AM
ATS*Mark
Aug 19, 2003 05:35 AM
TurbothisLS
Oct 14, 2002 06:13 AM
