EGT question?
Old Jan 8, 2003 | 04:44 AM
CiViC SiR's Avatar
Default Help befor i blow my engine?
is 1420F lean or rich boost 10psi @ 7000rpm
[Modified by CiViC SiR, 5:25 PM 1/8/2003]
Old Jan 8, 2003 | 05:35 AM
CiViC SiR's Avatar
Default Re: Help befor i blow my engine? (CiViC SiR)
any help
Old Jan 8, 2003 | 05:38 AM
glagola1's Avatar
nobody is gonna give you an answer for that because that's not how it works. you have to go to a dyno and get a wideband reading. Note the egts when you have reached the a/f that you feel comfortable with. Leave the dyno and keep an eye on the gauge. If you do any further modifications to your set up you can shoot for those egts you found to work at the dyno.
Also the gauge can be used as a warning device. you can't tune by egts alone.
Old Jan 8, 2003 | 12:13 PM
Speedworks801's Avatar
Default Re: Help befor i blow my engine? (glagola1)
It also depends on fuel and timing, if you could supply us with those, it would at least help.
Old Jan 8, 2003 | 01:16 PM
DRAGLS's Avatar
Default Re: Help befor i blow my engine? (Speedworks801)
you are running rich if it stays at 1420f till redline.
Old Jan 16, 2003 | 03:04 AM
CiViC SiR's Avatar
Default Re: Help befor i blow my engine? (DRAGLS)
what about 1500f is it lean or rich
Old Jan 17, 2003 | 08:26 AM
CiViC SiR's Avatar
any help please
Old Jan 17, 2003 | 08:54 AM
DC2R714's Avatar
Maybe This will help. This is old but good info.
There is a gross amount of misinformation floating around about exhaust gas temperatures. I have posted many times explanations to EGT questions. But it seems the search feature here tends to overlook them for whatever reason. I have found an excellent article done by the fine folks over at Simple Digital Systems. It is written in plain English, and is 100% correct. The link is http://www.sdsefi.com/techegt.htm and for those of you that are lazy to click, read below and learn!
There seems to be a lot of mystery and misinformation about using exhaust gas temperatures to tune engines. Claims by many EGT gauge manufacturers about it being the best way to tune an engine must be qualified. The BEST way to tune an engine is on the dyno- PERIOD. What EGT is good for is a reference for where the engine made maximum torque at wide open throttle. Once removed from the dyno, a similar air/fuel ratio can be established a later date by dialing in the mixture to achieve the target EGT. It is really the AFR that is important, not the EGT. Most engines will make maximum power at an AFR of between 11.8 and 13 to 1 however, the EGT may vary from 1250F to 1800F and is dependent on many factors.
It should be mentioned that the target EGT is valid only on the same engine configuration as was used on the dyno. If you change the ignition timing, cams, pistons, headers etc., the optimum EGT may also change. Raising the compression ratio with no other changes will drop the EGT at the same AFR. Retarding the ignition timing will generally raise the EGT at the same AFR. One engine might make best power at 1350 degrees while a very similar engine might be happier at 1500. You can't guess at this or you are simply wasting your money on the instrumentation. Wankel engines have higher EGTs than comparable piston engines due to their lower thermal efficiencies. 1800F is not uncommon here.
Some gauge manufacturers say you should tune to achieve maximum or peak EGT for maximum performance. This is incorrect. Peak EGT generally occurs at an AFR of around 14.7- 15.0 to 1 on gasoline. This is far too lean for maximum power and is dangerous under continuous WOT conditions. Many people think that the leaner you go, the higher the EGT gets. This is also incorrect. Peak EGT occurs at stoichiometry- about 15 to 1 for our purposes. If you go richer than 15 to 1, EGT will drop and if you go leaner than 15 to 1 EGT will ALSO drop. It is VERY important to know which side of peak EGT you are on before making adjustments. It is safe to say that peak power will occur at an EGT somewhat colder than peak EGT.
You can sometimes feel a lean of peak condition as the mixture is hard to ignite and power will be down a bit as well. Once the AFR gets close to 17 to 1 at WOT, generally the engine will start to lean misfire. Most tuners always recommend to begin jetting or programming from a known very rich initial setting and carefully leaning until torque falls off slightly, then going back richer to the point of max torque. Note the EGT at this setting. Be aware that altitude, barometric pressure and ambient air temperature may affect this optimal temperature to some degree.
Are EGT gauges better than AFR meters? Conventional narrow band oxygen sensors and digital LED meters are not the best devices to measure AFR in the richer ranges but they certainly warn of a too lean condition immediately and obviously, without translation by the driver and they are affordable. Meters combined with wide band sensors are laboratory quality usually, highly accurate and useful but very expensive and sometimes bulky. EGT gauges have the limitations above and are generally priced between the other two. I would suggest that the two types are complimentary. EGT gauges have the advantage of working long term with leaded fuel which will clog oxygen sensors. EGT gauges are widely used to set mixture on engines used for steady state high power applications where operation has been carefully documented such as in aircraft. The choice would depend on the application. Both are better if you can afford them.
All this is courtesy and copyrighted by Simple Digital Systems EFI http://www.sdsefi.com
Somebody please put this in some sort of archive
Old Jan 17, 2003 | 09:02 AM
chdesign
Guest
Posts: n/a
Default Re: Help befor i blow my engine? (DC2R714)
Good info there SDS is a great tuner IMO
Old Jan 17, 2003 | 09:28 AM
glagola1's Avatar
Default Re: Help befor i blow my engine? (chdesign)
Isn't that what I said?
yeaitsahonda
Engine Management and Tuning
30
Mar 22, 2012 05:39 PM
k_bster24
Apr 9, 2004 11:43 AM
azn98R
Feb 24, 2003 05:08 PM
Specialk
Feb 1, 2003 01:30 PM
