EGT probe in which runner?
Old Dec 13, 2001 | 02:23 PM
98Psi ITR's Avatar
Default EGT probe in which runner?
#1 for better accuracy or #4 because it will run lean?
Old Dec 13, 2001 | 03:07 PM
Ray's Avatar
Ray
New User
Default Re: EGT probe in which runner? (98Psi ITR)
I say #3 cause it runs the hottest.
Old Dec 13, 2001 | 03:56 PM
b18bturbo's Avatar
Default Re: EGT probe in which runner? (Ray)
# 3 is the way go ...
Old Dec 13, 2001 | 04:01 PM
TurboSedan's Avatar
New User
Default Re: EGT probe in which runner? (b18bturbo)
3's all around!
Old Dec 14, 2001 | 07:37 AM
98Psi ITR's Avatar
3? why wouldn't 4 be the one? Its at the end of the rail.
Old Dec 14, 2001 | 09:45 AM
Suprdave's Avatar
It doesn't matter which position its in, it has to do with which cylinder the Stock Intake Manifold has a tendency to dump the most air into.
Which is #3.
Suprdave
Old Dec 14, 2001 | 09:46 AM
D-SPEED's Avatar
i have gathered that the water flows from #1-->#4 cylinder, so obviously the farther the water goes, the hotter it gets, but since #4 is on the outside of the block, it dissipates heat a little better so #3 actually ends up being the hottest one, therefor delivering the highest EGT reading
edit: from what superdave says.....i dont know if what i said is true, this is just what i have seen people post on here before..
[Modified by D-SPEED, 6:47 PM 12/14/2001]
Old Dec 14, 2001 | 11:15 AM
98Psi ITR's Avatar
Default Re: EGT probe in which runner? (D-SPEED)
I am now enlightened
Old Dec 14, 2001 | 12:22 PM
rtype11's Avatar
typically #3 runs hotter but if you have had port work to the head it may be different, with standalone you can tune this problem out by individual cyl fuel/spark correction
LingLing
Feb 23, 2006 08:43 AM
hatchbackjdm
Dec 4, 2005 10:03 PM
NCSTIdriver
Nov 1, 2002 11:09 AM
EF-9SiR
19
May 6, 2002 09:18 PM
ASSMAN
Sep 1, 2001 01:07 AM
