egt probe = screwed
Old Aug 4, 2002 | 01:47 PM
DXturbo's Avatar
Default egt probe = screwed
i dropped my manifold off to get drilled and tapped for an egt probe and the shope placed it on the 3rd runner measuring 4th cylinder temps instead 2nd runner which measures 3rd cylinder temps. what can i do or should i jut leave it? what affects will i have on measuring temps? last but not least is this okay?
Old Aug 4, 2002 | 01:51 PM
b18bturbo's Avatar
Default Re: egt probe = screwed (redsi37)
it will be fine.
Old Aug 4, 2002 | 02:03 PM
Farnsrocket's Avatar
Default Re: egt probe = screwed (b18bturbo)
I thought #1 was in front of the driver, closer to the crank pulley and #4 was in front of the passenger, closer to the throttle body.
Old Aug 4, 2002 | 02:08 PM
PrecisionH23a's Avatar
Default Re: egt probe = screwed (Farnsrocket)
thats what i thought...
Old Aug 4, 2002 | 02:09 PM
DXturbo's Avatar
shoot, i could be wrong though.... this is what i though
1-3-4-2
can someone confirm this? thanks
[Modified by redsi37, 11:11 PM 8/4/2002]
Old Aug 4, 2002 | 02:15 PM
That is the firing order right? I thought the cylinders were numbered in order from 1 to 4 starting from the right side of the engine if you are looking at it from the front of the car.
Old Aug 4, 2002 | 02:17 PM
b18bturbo's Avatar
it starts from trhe right side going to the left
4321
Old Aug 4, 2002 | 02:21 PM
DXturbo's Avatar
sorry got the firing order messed up with cylinder numbers. anyhow, i guess im measuring the 2nd cylinder temps. vern says its okay so it guess its okay. how off would the egt temp be off comparing the two cylinders?
Old Aug 4, 2002 | 02:27 PM
b18bturbo's Avatar
num 3 is usually the hotest cyl on most hondas and usually the frist to let go. The one you are monitoring should only see minor difference. maybe 25 degrees.
Old Aug 4, 2002 | 02:29 PM
honestly, your EGT temps will be fine, dont worry about it. I have my probe placed after my DP flange and i got good readings, so if mine worked there im sure yours will give theoretically better read outs.
Old Aug 4, 2002 | 02:31 PM
DXturbo's Avatar
Default Re: egt probe = screwed (GudeH23a)
thanks everyone for reassuring me. just kind sucks the guy st machinf shop got runner 3 and cylinder 3 mixed up. again, thanks
Old Aug 4, 2002 | 04:03 PM
M.A.R.C.'s Avatar
4321
this is facing the car right? as in it's 4321 from passenger side to driver's side?
Old Aug 4, 2002 | 04:13 PM
Dutchie's Avatar
Default Re: egt probe = screwed (CivicRyda2k)
Yes.
1ludeEK
Honda Civic (2001 - 2005)
Aug 29, 2023 03:48 PM
JoeBlow2017
Jun 18, 2018 10:42 AM
B00ST2nR
Oct 31, 2004 08:54 PM
bluebullet
Dec 10, 2003 08:12 AM
Ochux
Sep 16, 2001 10:12 PM
