egt mounting question
i am getting ready to mount my egt on my mani, i have read that most people mount it on the 3rd cylinder, the problem with that is my wastegate tube is right there and i dont know if i have the room for it or if the WG being right there will mess up the reading, also its a autometer and they recomend if it is a turbo car to put it after the turbo, why would i want to do that? and finally it needs a 12 volt connection, is that a constant 12 volt or can i hook it up to my accesory?
thanks
thanks
Some put it on the manifold near runner # 3 and some on the downpipe. If you place it on the downpipe, you will see lower EGT's because the gas has a little room to cool down. I wouldn't use that as your only source to tune, because of this reason, there is no one temperature that you should shoot for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stickdeath »</TD></TR><TR><TD CLASS="quote">#3 tends to run hotter then the rest. as far as the wastegate I would say as long as it is a good 1 to 2" in front of it you should be fine</TD></TR></TABLE>
yeah there is like 3 in from the head to the WG so i dont know if it will be able to go there, although the WG is on a 90 degree elbow, do you think that will make a difference?
that's why you put it as close to the turbo as possible. it'll be like running the EGT on #2. it won't be the exact reading you want. but it'll be close. Usually when peopel can't mount it on #3, they mount it on the downpipe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman »</TD></TR><TR><TD CLASS="quote">heres a pic of my intsall
isn't that the #2 cylinder?
</TD></TR></TABLE>isn't that the #2 cylinder?
