EGT Installation
Old Oct 1, 2001 | 07:56 AM
The Punisher's Avatar
Default EGT Installation
I have been reading over all the EGT posts and I want to go over installtion with pictures. I am going to take the manifold to get the bung installed for the Probe, but I want to be absolutely sure I am getting it in the right place. I just signed up for photopoint, so I hope these pics come out. This is an H22A by the way.
Here is the Manifold with the bung sitting on the exhaust tube, do I have the right cylinder, and what about placement of the bung, does that look right?
After the bung is welded, the probe goes onto the connector like this?
Then the connector with probe is installed like this.
Any help on this is appreciated, thanks!
[Modified by gsr*lude, 4:29 PM 10/1/2001]
Old Oct 1, 2001 | 11:48 AM
adam's Avatar
Default Re: EGT Installation (gsr*lude)
pics don't work
Old Oct 1, 2001 | 11:52 AM
TurboInteg95's Avatar
the cylinder isnt as important as distance from the port. I believe somewhere along the lines of within an inch of the port is where it needs to be.
Old Oct 1, 2001 | 04:24 PM
2latev8's Avatar
New User
Lemme know what kinda temps your getting
Old Oct 1, 2001 | 05:13 PM
Default Re: EGT Installation (2latev8)
I don't have it installed yet, and I was hoping the pictures would work, but guess what. I can't seem to post an image that works on this site. Here is what I had laid out. I was going to have the bung installed on the #1 cylinder exhaust, about 3/4 to 1 inch from the flang that connects with the head. This bung is threaded, so the probe goes into a compression fitting and sticks out just a little bit from the threaded fitting that goes into the bung, with me, because I think I might have lost myself!
The only other thing that comes to mind is this, why would I have to use the provided bung if I could just get the exhaust manifold drilled and tapped?
gsr*lude
Old Oct 1, 2001 | 05:16 PM
LsTurbo91's Avatar
go to http://www.imagestation.com to host the pics.
Old Oct 4, 2001 | 04:16 PM
2latev8's Avatar
New User
i think the reason is cause the bung welded in place is a little more reliable, btw why put the egt by the no.1 cyl wouldnt the readings be more accurate if you put tht egt sensor close to the middle of all four cyls??
NuclearB18B
Jul 7, 2005 11:28 AM
mister2racer
Oct 30, 2004 11:44 PM
integranator
Feb 20, 2003 05:10 PM
PM-Performance
Jan 3, 2003 09:41 PM
Full-Race Geoff
Sep 22, 2002 10:53 PM
