EGT gauge placement issue?
Old Apr 19, 2003 | 11:22 PM
88ZCRX's Avatar
Default EGT gauge placement issue?
The probe for my autometer egt guage is too long to fit in the runner of my hf manifold. Do I just have to weld a bung on to the manifold for it to work or is there something I am missing? People keep on telling me it is not wise to weld to cast. Can anyone confirm or deny this?
Old Apr 20, 2003 | 08:16 AM
nitroice40's Avatar
Default Re: EGT gauge placement issue? (88ZCRX)
It should have came with a little fitting to go in there. You drill and tap the manifold and screw the fitting in and the probe goes in there then you tighten the probe down. Look on ebay for egt guages and in the pic you will be able to see the fitting.
Old Apr 20, 2003 | 05:27 PM
88ZCRX's Avatar
Default Re: EGT gauge placement issue? (nitroice40)
Yeah, I understand that is what you normally do, but the problem is that the probe is longer than the diameter of the runner.
Old Apr 20, 2003 | 08:35 PM
hybridsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88ZCRX &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I understand that is what you normally do, but the problem is that the probe is longer than the diameter of the runner. </TD></TR></TABLE>
Drill the hole at an angle, with the flow of exhaust
Old Apr 20, 2003 | 09:00 PM
Flamenco-T's Avatar
Default Re: EGT gauge placement issue? (hybridsol)
or drill the probe bung on top of the collector area that way you have more room than each runner diameter
stan
Old Apr 21, 2003 | 05:53 AM
88ZCRX's Avatar
Default Re: EGT gauge placement issue? (Flamenco-T)
Ok, thanks. I will try one of these methods.
platinum00
Dec 23, 2004 08:21 AM
adictionbass
Welding / Fabrication
Dec 13, 2004 10:03 AM
FredoSP
Feb 9, 2004 07:28 AM
boredracer408
Dec 6, 2003 08:46 AM
Ri5e
Sep 10, 2002 12:20 PM
